TheoPA3DSS
external drive not available after update
Fri Sep 18, 2020 10:13 pm
after this video tonight, i can't mount my external HD connected via usb anymore after a reboot
https://www.youtube.com/watch?v=8tTFgrOCsig&t=114s
as root i get this after fdisk -l:
Disk /dev/sda: 2.7 TiB, 3000592982016 bytes, 732566646 sectors
Disk model: External USB 3.0
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 33550336 bytes
Disklabel type: dos
Disk identifier: 0xc691c6b4
ofcourse /media/extern exist because it works until the update.
now i get these message:
Device     Boot Start       End   Sectors  Size Id Type
/dev/sda1         256 732563999 732563744  2.7T  7 HPFS/NTFS/exFAT
root@240:/home/pi#
root@240:/home/pi# ^C
root@240:/home/pi# mount -t auto /dev/sda1 /media/extern
[b]mount: /media/extern: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error.[/b]
What is going on ?
epoch1970
Re: external drive not available after update
Sun Sep 20, 2020 10:30 am
Comments appear to be open under that video. Did you ask there?
TheoPA3DSS
Sun Sep 20, 2020 6:23 pm
No, because it has nothing to do with the video but with the raspberry pi4
epoch1970
Sun Sep 20, 2020 7:23 pm
Ok. Good luck then.
TheoPA3DSS
Wed Sep 23, 2020 10:18 am
'solved' by start from scratch :D
Return to “Beginners”
