Shree_bha
Getting Unable to locate package error
Wed Mar 18, 2020 10:58 am
Hello
I'm new to raspberry, whenever im trying to install new packages then it will show the error like this: Unable to locate your packages?
what is the reason for this? how to overcome from this problem?can anyone help to solve this?
Thank you..
drgeoff
Re: Getting Unable to locate package error
Wed Mar 18, 2020 11:05 am
Does your RPi have a working connection to the internet?
DirkS
Wed Mar 18, 2020 11:06 am
Which OS + version do you use?
Please give an example of the package you're trying to install.
The command you issue.
The full error message you get.
If you use the command line on Raspbian: do you run 'sudo apt update' before installing a program?
Shree_bha
Wed Mar 18, 2020 12:31 pm
helloo..
I have the internet connection.
These are the OS information
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
before installing every time im running sudo apt-get update command also.
Errors are like this:
[email protected]:~ $ sudo apt-get install uv4l uv4l-raspicam
Reading package lists... Done
Building dependency tree
E: Unable to locate package uv4l
E: Unable to locate package uv4l-raspicam
rpdom
Wed Mar 18, 2020 12:44 pm
That could be because the packages uv4l and uv4l-raspicam don't exist in the standard repositories.
What instructions are you following (link please)?
Unreadable squiggle
pcmanbob
Wed Mar 18, 2020 12:57 pm
That's because the packages uv4l & uv4l-raspicam do not exist in the raspbian buster repositories,
You have to add another repository to your sources.list.
this is the only example I could find for adding it to buster, but note it still uses the stretch repository,
https://blog.cudmore.io/post/2019/12/14 ... an-buster/
I have not tested this so you are on your own if you do try it , if you have important data or programs on your SD card I would do a test install on a separate SD card to see if it will work correctly on buster.
SlowMoJoe
Sat May 23, 2020 7:10 pm
Do we have any update on this? Aren't these repositories necessary for the official cameras?
DirkS
Sat May 23, 2020 7:40 pm
No
Sat May 23, 2020 8:15 pm
raspivid/raspistill/picamera
Asus ChromeBox 3 Celeron is my other computer.
DirkS
Sat May 23, 2020 8:32 pm
SlowMoJoe wrote:
Sat May 23, 2020 7:56 pm
No? So, this page is total nonsense?
https://www.linux-projects.org/document ... -raspicam/
UV4L is not necessary for the official cams.
These packages give additional functionality, but that was not what you asked.
klricks
Sat May 23, 2020 8:45 pm
You are correct...
Evedently the OP is trying to install to Buster and the instructions are out of date and written for Stretch, Jessie, Wheezy.
https://www.linux-projects.org/uv4l/installation/
You would need to contact the maintainer of the web site to see if they will update the procedure for Buster if possible.
Return to “Beginners”
