Imperf3kt
[solved] How do I check the status of a GPIO from the terminal?
Tue Nov 19, 2019 11:48 pm
I'm trying to control the Pi GPIO via a program called Ren'Py. In order to do so I need to import RPI.GPIO into Ren'Py and write some functions that will toggle the GPIO pins high/low
I'm looking for a way to check if everything works without having to wire up an LED or some other hardware. Is there a way to see the output of a GPIO from within the terminal?
55:55:44:44:4C
52:4C:52:42:41
dustnbone
Re: How do I check the status of a GPIO from the terminal?
Tue Nov 19, 2019 11:56 pm
I think it's just gpio read
More info on the gpio command here
http://wiringpi.com/the-gpio-utility/
Imperf3kt
Wed Nov 20, 2019 12:06 am
Thanks, that's far simpler than I would have thought.
55:55:44:44:4C
52:4C:52:42:41
neilgl
Wed Nov 20, 2019 11:32 am
or maybe use raspi-gpio
raspi-gpio get [GPIO]
raspi-gpio set <GPIO> [options]
Imperf3kt
Re: [solved] How do I check the status of a GPIO from the terminal?
Wed Nov 20, 2019 9:29 pm
More options, thank you.
55:55:44:44:4C
52:4C:52:42:41
Return to “Beginners”
