deepakdeshp
Raspberry pi 1 26 pins and corresponding pins in Pi 3B
Wed Aug 28, 2019 2:01 pm
Pi 1 model has 26 pins while Pi 3b has 40. So is it that the first 26 pins of Pi 3B correspond to the 26 pins of Pi 1?
scruss
Re: Raspberry pi 1 26 pins and corresponding pins in Pi 3B
Wed Aug 28, 2019 2:11 pm
Almost. Issuing pinout shows the differences, here place side by side using the paste command:
         40 pin                          26 pin
   3V3  (1) (2)  5V                3V3  (1) (2)  5V
 GPIO2  (3) (4)  5V              GPIO0  (3) (4)  5V
 GPIO3  (5) (6)  GND             GPIO1  (5) (6)  GND
 GPIO4  (7) (8)  GPIO14          GPIO4  (7) (8)  GPIO14
   GND  (9) (10) GPIO15            GND  (9) (10) GPIO15
GPIO17 (11) (12) GPIO18         GPIO17 (11) (12) GPIO18
GPIO27 (13) (14) GND            GPIO21 (13) (14) GND
GPIO22 (15) (16) GPIO23         GPIO22 (15) (16) GPIO23
   3V3 (17) (18) GPIO24            3V3 (17) (18) GPIO24
GPIO10 (19) (20) GND            GPIO10 (19) (20) GND
 GPIO9 (21) (22) GPIO25          GPIO9 (21) (22) GPIO25
GPIO11 (23) (24) GPIO8          GPIO11 (23) (24) GPIO8
   GND (25) (26) GPIO7             GND (25) (26) GPIO7
 GPIO0 (27) (28) GPIO1
 GPIO5 (29) (30) GND
 GPIO6 (31) (32) GPIO12
GPIO13 (33) (34) GND
GPIO19 (35) (36) GPIO16
GPIO26 (37) (38) GPIO20
   GND (39) (40) GPIO21
Physical pins 3 & 5 have different functions now.
pcmanbob
Wed Aug 28, 2019 2:24 pm
It depends if you pi 1B is a revision 1 or a revision 2 as several pins changed between them,
the revision 2 has the same first 26 gpio pins as the pi1B, 2B, 3B & 3B+
To figure out which you have run
 cat /proc/cpuinfo
which will give the following results
[email protected]:~ $  cat /proc/cpuinfo
processor       : 0
model name      : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS        : 697.95
Features        : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2835
Revision        : 0002
Serial          : 000000003d0740f5
now if you look at the revision number which in this case is 0002 you can use this chart to figure out which revision you have
in this example I ran the command on my early pi 1B revision 1 with 256MB of ram.
if you are running raspbian jessie , stretch or buster you can also get the revision by running
cat /proc/device-tree/model
which when run on the same pi 1 B as used for the above gives this result
Raspberry Pi Model B Rev 1
old but useful https://www.raspberrypi-spy.co.uk/2012/ ... d-version/
deepakdeshp
Thu Sep 12, 2019 2:48 pm
 cat /proc/cpuinfo
processor       : 0
BogoMIPS        : 697.95
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2835
Revision        : 0002
Thanks for the update.
deepakdeshp
         40 pin                          26 pin
 GPIO5 (29) (30) GND
Thank you.
deepakdeshp
Sat Sep 14, 2019 2:07 am
My model is
pcmanbob
Sat Sep 14, 2019 9:47 am
My model is
In that case there are some differences between your gpio and that of the first 26 pins of the 40 pin gpio.
you need to use this pin layout for your pi.
As pins 3,5 & 13 are different gpio numbers.
Sat Sep 14, 2019 9:53 am
adieu
