SWUSTER
[Seek help] a problem about setting up wlan0 on pi 2b+
Sun Jun 17, 2018 12:14 pm
show "SIOCSIFFLAGS: Input/output error",when run "sudo ifconfig wlan0 up".
what can I do?
[email protected]:~ $ sudo ifconfig wlan0 up
DirkS
Re: [Seek help] a problem about setting up wlan0 on pi 2b+
Mon Jun 18, 2018 8:46 am
what can I do?
More info needed. Exact model Pi (2b+ does not exist!)
What brand / model WiFi module?
Which OS (+ version)?
Contents of /etc/wpa_supplicant/wpa_supplicant.conf and /etc/network/interfaces .
SWUSTER
Tue Jun 26, 2018 1:17 pm
PI model is 3B
wifi module is onboard
os and version is
[email protected]:~ $ uname -a
Linux raspberrypi 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
contents is
[email protected]:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
[email protected]:~ $ sudo cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
thank you @DirkS
SWUSTER
Tue Jun 26, 2018 1:27 pm
what can I do?
PI model is 3B
os and version is
contents is
update_config=1
thank you @DirkS
B.Goode
Tue Jun 26, 2018 1:35 pm
Have you checked the Raspberry Pi Foundation documentation here https://www.raspberrypi.org/documentati ... /README.md and noted the requirement to set the Country Code?
The wpa_supplicant.conf file you have posted is incomplete.
(Since the title of this thread is now acknowledged to be misleading, it would save confusion if you were to correct it, by editting it in your original post.)
