Bhabesh
Xbox one controller setup
Sun Feb 11, 2018 7:15 am
Can someone help me set up my Xbox one wireless controller? I tried
sudo apt-get install xboxdrv
but I get a message saying, "E: Unable to Locate Package xboxdrv". I am using Raspbian Jessie and need to configure my controller for robotics application.
rados-dataplicity
Contact: Website Facebook Twitter
Re: Xbox one controller setup
Mon Feb 12, 2018 1:01 pm
Did you add the repository where you're fetching from :?:
sudo add-apt-repository ppa:grumbel/ppa
sudo apt-get update
I tinker around with Raspberry Pis daily and make sure that people can easily access theirs remotely.
Community outreach @ dataplicity.com
Bhabesh
Mon Feb 12, 2018 2:11 pm
sudo apt-get update
I am getting the following error in the "sudo add-apt-repository" :
sudo: add-apt-repository: command not found
Please help me with this.
Thanks a lot :)
rados-dataplicity
Mon Feb 12, 2018 3:41 pm
Okay, you should be able to have this command after installing:
sudo apt-get install software-properties-common python-software-properties
Bhabesh
Mon Feb 12, 2018 5:10 pm
I tried that, getting the following result:
E: Unable to locate package software-properties-common
E: Unable to locate package python-software-properties
Thanks for all your efforts man. Please tell me if there is any way to resolve this. I am a total noob at this stuff.
rados-dataplicity
Tue Feb 13, 2018 11:19 am
What OS are you running ?
Bhabesh
Tue Feb 13, 2018 1:31 pm
I'm running Raspbian Jessie - is there any other specification that I'm supposed to mention here?
rados-dataplicity
Wed Feb 14, 2018 10:17 am
That's alright, hmmm... not sure why you're having trouble with apt perhaps installation from source will work ?
Instructions here:
https://github.com/xboxdrv/xboxdrv
Otherwise if I were you I would see if installing the latest Raspbian, Stretch, solves the apt problem
Bhabesh
Thu Feb 15, 2018 12:30 pm
That's alright, hmmm... not sure why you're having trouble with apt perhaps installation from source will work?
Instructions here:
Thanks for the suggestion. I will try reinstalling the latest Raspbian first. The required libraries are not there in my system. It gives me the following error when I try to install them:
E: Package 'libboost1.42-dev' has no installation candidate
E: Unable to locate package scons
E: Package 'libusb-1.0-0-dev' has no installation candidate
E: Unable to locate package libudev-dev
E: Unable to locate package libdbus-glib-1-dev
Bhabesh
Thu Feb 15, 2018 1:01 pm
Instructions here:
No progress. :cry: The controller pairs via Bluetooth but says that "No usable services on this device". And the github source requires scons which I am unable to get.
Bhabesh
Fri Feb 16, 2018 8:56 am
Instructions here:
Thanks for all the help. I was able to install Xboxdrv finally. I guess there was some problem with my Raspbian installation, I had to flash it again for this thing to work. But for some reason, It is unable to detect my Xbox one controller.
SCIEN
Tue Apr 03, 2018 7:18 am
I'm also interested of getting wireless Xbox one gamepad to work with Linux in python, unfortunately it seems that this lib is ment for Xbox 360 gamepad not Xbox one gamepad.
Return to “Beginners”
Who is online
Users browsing this forum: No registered users and 12 guests
