brianharding
accessing LAN NAS by name not IP Address
Sat Jan 13, 2018 10:43 am
I can successfully mount access to my NAS device using FSTAB entry, BUT only if i specify the NAS IP Address
//192.168.1.130/Docs /home/pi/northfields cifs username=xxx,password=xxx,defaults 0 0
//192.168.1.130/BackUps /home/pi/BackUps cifs username=xxx,password=xxx,defaults 0 0
but if i use the NAS name and not the ip it fails.
if i ping the ip address its fine.if i ping the NAS name it gives me some weird internet address in the world. ( i guess there is a site out there with the same name as my local NAS)
ive checked the capitalisation is correct for the local name
If i ping from my windows 10 pc it all shows fine ( ie pingiing the name gives the correct IP address)
I am a reasonable PC expert, but a newbie on the PI and Linux.
thanks
neilgl
Re: accessing LAN NAS by name not IP Address
Sat Jan 13, 2018 2:59 pm
Probably you could install samba on the pi and set up a share in that using the name of your NAS (e.g. Fred)
Then from Windows 10 File Explorer look under Network to see "RASPERRYPI" then the share "Fred"
brianharding
Sat Jan 13, 2018 3:31 pm
thanks ill give that a try later. i only need to access the nas from the PI . accessing the PI and the NAS from windows 10 works fine.
ill update the result later
neilgl
Sat Jan 13, 2018 11:27 pm
OK what is in your fstab for that NAS
brianharding
Sat Jan 13, 2018 11:34 pm
I’m sorry I am confused by the question
The fstab content was in the original question
Im not able to try samba approach until tmrw
bertlea
Sun Jan 14, 2018 12:53 am
How about just adding the IP to name mappings to the /etc/hosts file on the Pi?
brianharding
Sun Jan 14, 2018 7:43 am
The IP address assigned to the nas isn’t a static one
drgeoff
Sun Jan 14, 2018 9:27 am
Is there a good reason for that? Set the DHCP server (on your router?) to always give it the same address.
Sun Jan 14, 2018 10:35 am
Everything that runs a service on your LAN should have a static IP address or needs to run zero configuration networking (aka Zeroconf, aka Bonjour, aka mDNS).
If your NAS supports Bonjour you may be able to find it with hostname.local (for example your Raspberry Pi (default hostname=raspberrypi) will appear as raspberrypi.local on your network if the Avahi daemon is running).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
brianharding
Sun Jan 14, 2018 12:17 pm
Hi that’s interesting i had always assumed it was better to have non-static to be flexible thanks for that.
Sun Jan 14, 2018 12:48 pm
Without doing any special configuration on your network you get 253 addresses (192.168.xxx.1 to .254) to play with.
On my network every address from 192.168.1.1 to 192.168.1.40 is reserved for fixed IP addresses for Raspberries (I've, currently, got fourteen). Every address from 192.168.1.41 to 192.168.1.100 is the DHCP pool for phones, laptops, tablets, smart TVs, my Arduino, esp8266s and a couple of Wemoses. Addresses above .230 are also reserved for fixed IPs. My NAS is at 192.168.1.230. My printer is at 192.168.1.249. My old WiFi AP is 192.168.1.250. The router is 192.168.1.254. There's a big gap from .101 to .229 that's free for future use.
Most I've ever seen is 31 devices connected (I let visitors connect, I don't restrict anything except dailymail.co.uk is DNS poisoned).
MQTT Evangelist
davidcoton
Sun Jan 14, 2018 12:51 pm
It's better NOT to define a static address on each PC, NAS, or printer itself. That results in making equipment difficult to move between networks.
However many DHCP servers (usually part of the router or other AP) can be told to issue the same IP address to each node based on its (supposedly) unique MAC address.
That means that each network maintains its integrity and a consistent set of addresses.
The remaining problem is for each network client to find other resources. Looking for a fixed IP address has limitations, but using a name finding service (as per @DougieLawson) overcomes this.
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
Sun Jan 14, 2018 1:09 pm
I also run a bind9 DNS server (which is how I poison dailymail.co.uk) so that every machine with a static IPv4 and static IPv6 (I switched back to use slaac hardware) can be addressed on my .bogus domain.
Bonjour is easier than bind9. Bind9 is easier than /etc/hosts files.
MQTT Evangelist
brianharding
Sun Jan 14, 2018 1:16 pm
@david and @dougie - thanks. i get it now.
Now, back to my original issue.
I have now installed samba and i can see its working from windows as i have allocated a couple of shares and i can see them from windows explorer.
But it hasnt fixed my original problem of being able to access my NAS by name.
if i ping the op address - 192.168.1.130 - i get a response fine
[email protected]:~ $ ping 192.168.1.130
PING 192.168.1.130 (192.168.1.130) 56(84) bytes of data.
64 bytes from 192.168.1.130: icmp_seq=1 ttl=64 time=3.52 ms
64 bytes from 192.168.1.130: icmp_seq=2 ttl=64 time=6.91 ms
64
if i ping the name i get the odd one which oi guess is coming from somewhere out ion the wild
[email protected]:~ $ sudo service smbd restart
[email protected]:~ $ ping northfields
PING northfields (92.242.132.15) 56(84) bytes of data.
64 bytes from unallocated.barefruit.co.uk (92.242.132.15): icmp_seq=4 ttl=242 time=14.4 ms
64 bytes from unallocated.barefruit.co.uk (92.242.132.15): icmp_seq=5 ttl=242 time=15.0 ms
64 bytes f
as a reminder my fstab is
proc /proc proc defaults 0 0
/dev/mmcblk0p6 /boot vfat defaults 0 2
/dev/mmcblk0p7 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
anyone help and point me int he right direction
thanks
Sun Jan 14, 2018 1:25 pm
Does your NAS do NFS? Because that's orders of magnitude better with Linux (no credentials needed).
What do you get from
sudo mount -o user=xxx -t cifs \\\\192.168.1.130\\Docs /mnt
Note: it's user=xxx not username=xxx
MQTT Evangelist
brianharding
Sun Jan 14, 2018 1:52 pm
[email protected]:~ $ sudo mount -o user=xx -t cifs \\\\192.168.1.130\\Docs /mnt
Password for [email protected]\192.168.1.130\Docs: *********
[email protected]:~ $ sudo mount -o user=xxx -t cifs \\\\northfields\\Docs /mnt
Password for [email protected]\northfields\Docs: *********
mount error(115): Operation now in progress
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Sun Jan 14, 2018 2:21 pm
115 means it can't find northfields as an NMBD domain.
Do you have a machine running as domain master? Do you have two machines fighting to be domain master?
What does nmblookup -A 192.168.1.130 give you?
If you've got smbclient installed what does smbtree -b -U pi give you?
MQTT Evangelist
brianharding
Sun Jan 14, 2018 2:36 pm
i thought i found it, the smblookuop shows the nas as capitalised , but the capitalisation didnt work either..
i also changed to NFS that seems to work ( with the Ip address of course)
1)
[email protected]:~ $ nmblookup -A 192.168.1.130
Looking up status of 192.168.1.130
NORTHFIELDS <00> - B <ACTIVE>
NORTHFIELDS <03> - B <ACTIVE>
NORTHFIELDS <20> - B <ACTIVE>
WORKGROUP <00> - <GROUP> B <ACTIVE>
WORKGROUP <1e> - <GROUP> B <ACTIVE>
MAC Address = 00-00-00-00-00-00
2) i dont - command not found
3) i havent heard of domain master before, googline around i dont think i have nor need one.
its a relatively simple lan , bb router acts as dhcp, ok - lots of devices circa 20, wifi access points etc.
mt windows and mac devices can find northfields ok
Pinging northfields [192.168.1.130] with 32 bytes of data:
Reply from 192.168.1.130: bytes=32 time=1ms TTL=64
Reply from 192.168.1.130: bytes=32 time=2ms TTL=64
Reply from 192.168.1.130: bytes=32 time=4ms TTL=64
Ping statistics for 192.168.1.130:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 4ms, Average = 2ms
C:\Users\brian>
brianharding
Sun Jan 14, 2018 2:38 pm
btw, checking my router, the NAS shows as lower case...
Sun Jan 14, 2018 2:39 pm
You need a domain master running NMBD that's the thingy that gets the Windows CIFS/Samba network addressing by name working. The important thing is ONE domain master per network.
Your NAS may be doing that.
CIFS/Samba doesn't care about upper vs lower case names because Windows never cared about upper vs lower case.
Stick with NFS, it's easier, more secure and owner/group/world permissions "just work" with NFS.
MQTT Evangelist
brianharding
Sun Jan 14, 2018 4:36 pm
so, i am about to give up and stick with ip adressing :(
I used
[email protected]:~ $ nmblookup -M -- -
192.168.1.1 __MSBROWSE__<01>
which seems to suggest that my gateway router is acting as master browser. I am guessing that something within my network is storing names to ip address and providing lookups to those devices but just not to the raspberry pi.
thanks for the help
Who is online
Users browsing this forum: No registered users and 24 guests
