Qypol342
I can't modifi my raspberry with ssh
Sat Jan 13, 2018 8:48 am
hello, I can't modifi my raspberry with ssh with winSCP I have a error:
Permission denied.
Error code: 3
Error message from server: Permission denied
I have actived ssh
I am trying to transfer a minecraft plugins in to /home/pi/minecraft/plugins
and i use login "pi"
jahboater
Re: I can't modifi my raspberry with ssh
Sat Jan 13, 2018 9:39 am
We need a little more information than that.
I assume you have enabled ssh, you are using the right user on the right host, and that user has permission to write to the destination.
For example: trying to copy a configuration file into /etc should normally fail for user "pi".
What is the file you are trying to copy and where to?
Qypol342
Sat Jan 13, 2018 12:48 pm
i have actived ssh
i am trying to transfer a minecraft plugins in to /home/pi/minecraft/plugins
jahboater
Sat Jan 13, 2018 1:55 pm
Just a guess, try "pi", not "PI" - it is case sensitive.
Have you in the past used "sudo" when working in your home area?
That could leave directories or files owned by root.
Qypol342
Sun Jan 14, 2018 2:10 am
I don't rember but it posibel that I used sudo
Qypol342
Sun Jan 14, 2018 2:18 am
i have actived ssh
mattmiller
Sun Jan 14, 2018 10:55 am
Can you transfer it to /home/pi
Return to “Beginners”
