Leeloo
Pi Zero funky usb wireless keyboards?
Fri Oct 06, 2017 10:20 pm
I got my zeroW the other day put noobs on a spare SD card usb everything works except the wireless keyboard/mouse dongle isn't working :S
I tested the keyboard in several over devices inducing the pi3 and it works fine. was starting to worry could my board / port have come doa but I got around to testing 2 different wired usb keyboards and they work perfectly fine!
I had people telling me "you can plug ANY gamepad into a pi and it will just work" but I never expected it would have issues with something like a keyboard/mouse, is the Zero funny with certain usb hardware? that the case id really wish I had known before ordering .
TLDR my keyboard is the "PKB-1720 Mecer Wireless Mini Keyboard" I have tested the PizeroW with both my original 1amp psu and the official Pi3 power supply to the same results. it works fine with a logitech usb wave thingy keyboard and a belkin keyboard mouse combo thing but I kind of need it wireless.
is there anything I can do to troubleshoot and get it working or do I pretty much have to get a new keyboard? is there any indicator of which keyboards will work or not?
DirkS
Re: Pi Zero funky usb wireless keyboards?
Sat Oct 07, 2017 10:32 am
Does it show up when using
lsusb
Plug in the dongle *after* booting the Pi and then check the log with
dmesg
Sat Oct 07, 2017 10:58 am
lsusb
FTFY :-)
DirkS
Sat Oct 07, 2017 11:02 am
lsusb
FTFY :-)
:shock: edited my post
Cheers!
Leeloo
Sat Oct 07, 2017 1:13 pm
lsusb
Bus 001 Device 003: ID 05a4:1700 Ortek Technology, Inc.
dmesg
[  459.436933] systemd[1]: apt-daily.timer: Adding 9h 45min 22.464008s random time.
[  459.439749] systemd[1]: apt-daily-upgrade.timer: Adding 43min 44.612333s random time.
[  517.844419] usb 1-1: USB disconnect, device number 2
[  529.544366] Indeed it is in host mode hprt0 = 00021501
[  529.744227] usb 1-1: new full-speed USB device number 3 using dwc_otg
[  529.744518] Indeed it is in host mode hprt0 = 00021501
[  529.976149] usb 1-1: New USB device found, idVendor=05a4, idProduct=1700
[  529.976167] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  529.976174] usb 1-1: Product: W/L Keyboard/Mouse
[  529.976182] usb 1-1: Manufacturer: ORTEK
[  530.120924] input: ORTEK W/L Keyboard/Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:05A4:1700.0003/input/input2
[  530.188869] ortek 0003:05A4:1700.0003: input,hidraw0: USB HID v1.10 Keyboard [ORTEK W/L Keyboard/Mouse] on usb-20980000.usb-1/input0
[  530.194059] input: ORTEK W/L Keyboard/Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:05A4:1700.0004/input/input3
[  530.268131] ortek 0003:05A4:1700.0004: input,hidraw1: USB HID v1.10 Mouse [ORTEK W/L Keyboard/Mouse] on usb-20980000.usb-1/input1
not sure why it says disconnect but to me it looks like it should be working? any ideas ? should I be able to probe the devices somehow and see if they are working ?
edit:I tried to "cat platform-20980000.usb-usb-0\:1\:1.0-event-kbd" pressing the keys does nothing
DirkS
Sat Oct 07, 2017 3:53 pm
Output looks fine to me.
Can't see a reason why it's not working.
Re disconnected: did you unplug and then plug in the dongle while the Pi was running?
That would explain why log says it was disconnected first.
Leeloo
Sat Oct 07, 2017 4:11 pm
yeah I did some unplgging if I recall mostly just unplugged the wavetech wired keyboard and plugged in the wireless dongle.
I tried to "cat platform-20980000.usb-usb-0\:1\:1.0-event-kbd" pressing the keys does nothing (it should right?)
almost like the keyboard isn't connecting to the dongle maybe? should I risk getting a new keyboard, could the Pi be faulty ?
HawaiianPi
Sat Oct 07, 2017 6:01 pm
How are you attaching the wireless keyboard dongle to the Pi Zero?
Problems with USB devices on the Pi Zero are often related to the USB-to-microUSB adapter used.
My password is the last 8 digits of Pi.
Leeloo
Sat Oct 07, 2017 7:33 pm
the wireless nub is plugged directly into a $2 5cm usb otg cable that was purchased for a phone that is directly plugged into the pi. I don't have another otg cable to test.
Leeloo
Thu Oct 12, 2017 8:51 pm
finally dug out my old cheapo usb hubs and it wouldn't worth with either one was powered. kind of given up on getting the keyboard working my searching seems to be like the zero just hates some usb devices
HawaiianPi
Fri Oct 13, 2017 6:16 pm
Sounds like that keyboard is not compatible. If it doesn't work on a powered hub then something is screwy. I've had good luck with the Logitech Unifying devices. I have a K400r keyboard and several different mice, and I they have worked on everything, including Raspberry Pi computers from my original model B to my Pi3 and my Zero with a tiny OTG adapter.
Who is online
Users browsing this forum: RaTTuS and 31 guests
