solidago
Monitoring a 12v circuit
Wed Sep 13, 2017 7:01 pm
Essentially I need a Pi to monitor a 12v circuit. I want to Pi to know when a circuit switch has been closed. When that happens the Pi will take some action.
Clearly I cannot connect the Pi directly to the 12v circuit and I need to place something in between. My knowledge of the hardware options is very limited and am hoping for some advice
KLL
Re: Monitoring a 12v circuit
Thu Sep 14, 2017 1:23 am
to keep the circuits isolated can use a 12VDC relay in the 12VDC circuit.
the ( potential free ) contacts of the relay you can use / connect like a push button
follow the manuals about reading a GPIO connected push button.
drgeoff
Thu Sep 14, 2017 7:23 am
Or an opto-isolator plus a couple of resistors.
pcmanbob
Thu Sep 14, 2017 9:31 am
Drew this up for some one on here a while ago.
just to be clear the ground under the 12v is the ground for the 12v circuit not the pi.
you can simply leave the switch shown out of the circuit for you circuit.
Please only ask questions in the forum I will not answer questions sent to me directly via PM
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
solidago
Sat Nov 11, 2017 11:43 am
Opto isolator used and working perfectly thanks to all who responded.
Return to “Beginners”
Who is online
Users browsing this forum: No registered users and 43 guests
