serargi
Creating a bridge between two nets in the same LAN using raspberry pi
Wed Sep 13, 2017 2:28 pm
Hello!
I needed to use raspberry as a bridge for two different nets in the same LAN. It is because it's a small biz LAN without VLAN (not supported by switch or routers). Also, the routers don't allow two different IP address.
I saw a lot of info "how to bridge Wi-Fi and eth0 using Raspi" but not how to bridge two nets in the same LAN. So, I hope it helps to anyone:
In my scenario, I have 192.168.1.0/24 and 192.168.0.0/24 nets.
- 0.0/24 does not use DHCP and has 0.1 as a GW (raspberry)
- 1.0/24 uses DHCP with 192.168.1.1 (and secondary dns) as s GW and 192.168.1.10 as a primary DNS.
- With that scenario, I don’t need extra DNS or DHCP (dnsmasq is not necesary)
So, I need raspberry to route 0.0/24 to the Internet and to 1.0/24.
0. Update and upgrade
sudo apt-get update
sudo apt-get upgrade
1. Static IP for raspberry (PI v1 is enough) and create secondary eth0:0
sudo /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto eth0
iface eth0 inet static
    address 192.168.1.199
    netmask 255.255.255.0
    gateway 192.168.1.1
auto eth0:0
iface eth0:0 inet static
    address 192.168.0.1
2. DCHP disabled
pi@raspberrypi:~ $ sudo systemctl disable dhcpcd
3. At this time, there is connectity from the raspberry to 0.0/24 and 1.0/24 LAN. We want to bridge 0.0/24 to 1.0/24
sudo nano /etc/sysctl.conf
#net.ipv4.ip_forward=1 replace with net.ipv4.ip_forward=1
then:
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
4. Playing with iptables: traffic is forwarded from our eth0:0 interface over to our eth0 connection. This means that anyone connecting to the Ethernet will be able to utilize our eth0 internet connection.
Run the following commands to add our new rules to the iptable:
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o eth0:0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i eth0:0 -o eth0 -j ACCEPT
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
then:
sudo nano /etc/rc.local
add above exit 0:
iptables-restore < /etc/iptables.ipv4.nat
5. DNS:
pi@raspberrypi:~ $ sudo nano /etc/resolv.conf
nameserver 192.168.1.11 #local primary DNS server
nameserver 192.168.1.1 #local secondary DNS server
nameserver 8.8.8.8 #google DNS server
Now, you should bridge from 0.0/24 to 1.0/24:
- 0.0/24 can use the Internet
- You can connect from 0.0/24 to 1.0/24.
Reboot your pi and check again :)
*EXRA: To connect from 1.0/24 to 0.0/24, you have to create a route in the 1.1 router. All the traffic from 1.0/24 to 0.0/24 should go through 192.168.1.199 (eth0 of raspberry pi)
W. H. Heydt
Re: Creating a bridge between two nets in the same LAN using raspberry pi
Wed Sep 13, 2017 6:18 pm
Do it just like a WiFi bridge, but use a USB to Ethernet adapter instead of the WiFi for the other connection.
What you are trying to do is, in fact, a bridge. A network bridge echoes all packets received on one connection to the other connection. The smarter version is a router. A router only forwards packets that are for the other connection, so that would work for you as well. (Routers are, I fear, rather misunderstood these days because most people think of then as a LAN-to-WAN connection device, especially since most SOHO routers have a built-in switch. But in actual networking, a router simply does a smart job of interconnecting two networks. The router/bridge relationship is very much like the switch/hub one.)
serargi
Wed Sep 13, 2017 9:57 pm
Completly agree with you!
In this case, with the solution I posted it works fine! Agree is not the best solution but was the easy way to dont change anything in the LAN, and to not buy more stuff... so, finally the easy temp solution! :)
Who is online
Users browsing this forum: Sir_Bashalot and 39 guests
