gintoki3452
help with fuzzy logic for robot sensor
Fri Jun 03, 2016 1:40 pm
hello someone knows a library for raspberry fuzzy logic to apply to a robot that avoids obstacles with hc-SR04 sensor.
a bit of code that I need to apply my fuzzy logic
from Tkinter import *
import RPi.GPIO as GPIO
import time
#plt.plot(distacex_small,distacex_safe,distacex_big)
#plt.show()
def measure():
 # This function measures a distance
 GPIO.output(GPIO_TRIGGER, True)
 time.sleep(0.00001)
 GPIO.output(GPIO_TRIGGER, False)
 start = time.time()
 while GPIO.input(GPIO_ECHO)==0:
   start = time.time()
 while GPIO.input(GPIO_ECHO)==1:
   stop = time.time()
 elapsed = stop-start
 distance = (elapsed * 34300)/2
 return distance
GPIO.setmode(GPIO.BCM)
# Define GPIO to use on Pi
GPIO_TRIGGER = 20
GPIO_ECHO    = 21
#motor
GPIO.setup(18, GPIO.OUT)
pwm = GPIO.PWM(18,100)
left_in1_pin = 24
left_in2_pin = 23
right_in1_pin = 22
right_in2_pin = 27
class Motor(object):
    def __init__(self, in1_pin, in2_pin):
        self.in1_pin = in1_pin
        self.in2_pin = in2_pin
        GPIO.setup(self.in1_pin, GPIO.OUT)
        GPIO.setup(self.in2_pin, GPIO.OUT)
    def clockwise(self):
        GPIO.output(self.in1_pin, True)
        GPIO.output(self.in2_pin, False)
    def counter_clockwise(self):
        GPIO.output(self.in1_pin, False)
        GPIO.output(self.in2_pin, True)
    def stop(self):
print "Ultrasonic Measurement"
# Set pins as output and input
GPIO.setup(GPIO_TRIGGER,GPIO.OUT)
# Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN)
# Echo
# Set trigger to False (Low)
time.sleep(0.01)
time.sleep(0.001)
begin = time.time()
Who is online
Users browsing this forum: Baidu [Spider] and 13 guests
