shaurz
Re: CFLAGS for optimal code
Mon May 07, 2012 12:56 am
What are the best CFLAGS for gcc to generate the most optimized code specifically for the Raspberry Pi, to use all available CPU features for example?
jannis
Mon May 14, 2012 6:49 am
This depends on the version of your gcc and the flags the other stuff has been compiled with. I currently go with:
CFLAGS="-O2 -mcpu=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -pipe -fomit-frame-pointer"
That obviously only works if the rest of your system is hardfp, too. Otherwise, use -mfloat-abi=softfp
