rrmcbeth
Re: Berry Box - The Transparent Case
Sat Apr 14, 2012 2:14 pm
It's possible that someone may want to build a "Super Computer" using multiple RPi's.   I believe that some post grad students built one using 64 PC's.  Just think how low cost, low power and small physical size it would be.
One of the first digital computers (the ENIAC) was built in the 40's. It had 17,468 vacuum tubes, 1500 relays, 70,000 resistors, 5,000,000 solder connections and consumed 150,000 watts.  64 RPi's would consume less than 100 watts.  Look how far we have come and what the future holds.
bruceberry
Sat Apr 14, 2012 2:31 pm
Yes I'm familiar with this, we have a cluster here at Swansea Uni, they are very cost effective. Though typically a cluster consists of more standard computing hardware, something like a core i7 with a healthy amount of ram.
I keep reading the new metric of comparison in HPC is GFLOPs/watt though... Any idea's on how the R-Pi compares in terms of GFLOPs/watt to a typical cluster node?
rrmcbeth
Sat Apr 14, 2012 8:55 pm
I have no idea.  A GFLOP is 1,000,000,000 floating point operation/sec.  A MFLOP = 1,000,000 per seconds. The RPi has embedded math hardware.  So lets make some assumptions:
1)   Clock = 700 mHz
2)   1 Instruction cycle = 2 clock cycles.
3)   A Flop instruction  = 2 instruction cycles
4)   So you get 175,000,000 flops/sec or 175MFLOPS = .175 GFLOPs
5)   The RPi consumes about 1.5 watts.
6)   Therefore, we get 116 MFLOPS/watt/second
I see them going to 100 GFLOP these days. (Power for that speed is needed to calculate GFLOP/Watt)  But 116 MFLOP/W is not bad for a $35 board.
bruceberry
Sun Apr 15, 2012 1:43 pm
Interesting, when the availability is better I'm tempted to buy 10 and do some benchmarking...
vesku
Mon Apr 16, 2012 8:13 am
bruceberry said:
@vesku
The case can be "stacked" back to back, but that would only give you a stack of two. It would however be possible to build a larger structure out of lego to mount all of your Berry Box's too
We were really anticipating much demand for multiple cases, how many do you need?
I need maybe five boxes. Can I just pay 5x5£ through WeFund and pay shipping separately when you are ready to send boxes?
bruceberry
Mon Apr 16, 2012 9:46 am
Hey Vesku,
Shipping is constant regardless of quantity, so if you order 1 box or 5 box's the shipping cost is the same. If you want 'n' box's that would be, total = n*£5+shipping. I'm guessing you'd want EU delivery which would come to £28 total.
Thank's Vesku!
Jeff2
Tue Apr 17, 2012 2:10 pm
Looks like funding is up to 20% of the goal:
http://www.wefund.com/project/berry-box
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Wed Apr 18, 2012 2:54 am
In fact, the GPU in the Pi puts out 26,000,000,000 FLOPS ... yes, that's 26 GIGA-FLOPS!  So, the actual efficiency is ~17.3 GFLOPS/watt/second.
That's why the Pi can render Quake 3 Arena scenes pretty much on-demand with very little lag only when a large number of players wind up in proximity in a scene (e.g., dozens).  It can render about 40,000,000 Gouraud-shaded polygons per second, which puts it between an Original Flavor X-Box and an X-Box 360, which is somewhat below a Sony PS/3.
Now, that's nowhere near i7 levels of performance, so, the Pi is in no danger of putting Intel out of business for high-end clusters.  However, these are single-core CPU-GPU and the ARM CPU is only running at 700 MHz (the GPU is actually running at a slower clock rate.  It has parallel circuits whose sole purpose in life is to multiply a bunch of floating-point 3-D matrices simultaneously and send the result directly out of the HDMI port running at up to 1080p at 30 - 60 frames per second (you have to dedicate half the RAM to the GPU at boot time for the latter).
rrmcbeth
Wed Apr 18, 2012 12:47 pm
Wow! I was off by a factor of about 150.   How is this calculated?   How many parallel floating point circuits does it have?   Is there a good description on the inner block diagram of the chip somewhere on the WEB?
bruceberry
Thu Apr 19, 2012 12:27 pm
Thanks Jeff, be nice if we made it
@Jim and rrmcbeth
GPGPU has been discussed quite a lot on these forums, the general concensus is that there is no suitable software platform to do real GPGPU on the raspberry Pi. And unless broadcom decide to implement it, we probably wont get one.
GPGPU is still possible, but it is limited by what you can do with OpenGL ES. For real scientific computing you really need double precision as well. Again its possible to achieve double precision with single precision hardware through some clever maths, but it severely reduces the efficiency...
bruceberry
Wed Apr 25, 2012 3:30 pm
Hey all,
Our Raspberry Pi arrived this week. With some minor modifications our prototype fits like a glove!
We've also been busy carrying out simulations of the injection moulding of the Berry Box. Stay tuned for some pretty pictures and some info!
tumblebomb
Fri Apr 27, 2012 2:33 pm
Hi Bruce,
This is a bit of tangential question (don't know if that word works but it sounds good). If the crowd source project falls through (god forbid) maybe there could be a 3D printing option setup with one of the shops online so people may still be able to get the a same/similar designed case ?
bruceberry
Fri Apr 27, 2012 2:49 pm
Hey tumblebomb
If crowdfunding fails, we will reveal our contingency plans
By the way, our website went live today, check it out at http://www.berrybox.co.uk
Bruce
Ferret141
Sat Apr 28, 2012 1:57 am
Can't say LEGO?
"Compatible with popular Danish building blocks"
bruceberry
Sat Apr 28, 2012 7:32 am
Yes, we were advised not to mention it directly.
So how about a competition, how many ways can you find to say *that* word without actually saying it...
arm2
Tue May 01, 2012 8:22 pm
Sorry if I'm missing the obvious, but what about it is L### compatible?
jbeale
Tue May 01, 2012 8:41 pm
The photo shows the new case connected by four screws to a framework on wheels, which might be part of a L*** kit (?)
pygmy_giant
Wed May 02, 2012 12:13 am
If crowdfunding fails it may be just because your timing's off – float it again in a few months when there are more Pis in the wild and you might get more interest…?
I hope you are suitably proud - I'm tempted....
Ostendo ignarus addo scientia.
Lob0426
Wed May 02, 2012 5:12 am
This is the most unique case I have seen so far. might not be too practical for most but it does have its appeal. It is on Ebay.
http://www.skpang.co.uk/catalo.....0001_2.jpg
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
Danbury Shakes
Wed May 02, 2012 7:56 am
Nice work on the case.
Using a numeronym it could be it has L3 or L2O connectivity
markb
Wed May 02, 2012 7:59 am
I seem to remember a Simpson's episode that involved a visit to 'BlockoLand". Surely you could state that the the Berry Box is 'Blocko' compatible?
Ferret141
Wed May 02, 2012 11:45 am
Maybe Mega Blocs will want a piece of the action.
davesedar
Wed May 02, 2012 12:01 pm
according to google translate it is  "????"   in Belarusian,
which looks kind of cute,
as the first character looks like the symbol for "pi".
what's the prize?
Ravenous
Wed May 02, 2012 2:15 pm
I suppose various puns are possible on "Let Go", "Legion", etc...
pygmy_giant
Wed May 02, 2012 11:00 pm
you could say something like 'our L3-GO mounting system is compatible with market leading construction sets'.
Amazon don't mince their words – http://www.amazon.co.uk/100-Le.....0466KGRQ/2
