dus ik volg deze tutorial: http://learn.adafruit.com/adafruit-rasp ... r/hardware
met dit als python code:
import RPi.GPIO as io
io.setmode(io.BCM)
in1_pin = 4
in2_pin = 17
io.setup(in1_pin, io.OUT)
io.setup(in2_pin, io.OUT)
def set(property, value):
try:
f = open("/sys/class/rpi-pwm/pwm0/" + property, 'w')
f.write(value)
f.close()
except:
print("Error writing to: " + property + " value: " + value)
set("delayed", "0")
set("mode", "pwm")
set("frequency", "500")
set("active", "1")
def clockwise():
io.output(in1_pin, True)
io.output(in2_pin, False)
def counter_clockwise():
io.output(in1_pin, False)
io.output(in2_pin, True)
clockwise()
while True:
cmd = raw_input("Command, f/r 0..9, E.g. f5 :")
direction = cmd[0]
if direction == "f":
clockwise()
else:
counter_clockwise()
speed = int(cmd[1]) * 11
set("duty", str(speed))
Volgens mij staat /sys/class/rpi-pwm/pwm0/ ook niet op de pi.
dit is hoe alles eruit ziet
Het lukt me trouwens wel om de motor te laten draaien met dit script:
import RPi.GPIO as gpio
gpio.setmode(gpio.BCM)
gpio.setup(4, gpio.OUT)
gpio.setup(17, gpio.OUT)
while True:
gpio.output(4, gpio.HIGH)
gpio.output(17, gpio.LOW)
