SSD juist inschalen met Gparted
Posted: Wed Jul 31, 2019 1:53 pm
Ik wilde deze handleiding volgen http://www.makerspace-uk.co.uk/setting- ... sktop-kit/
Bij deze stap loop ik vast:
Ik krijg namelijk ext4 niet vergoot Wat doe ik verkeerd of wat moet ik aanpassen en hoe in Gparted?From this it can be seen that the copied file system only uses a fraction of the SSD, leaving the major proportion of the device unallocated. In order to use this space, all we needed to do was to resize the ext4 partition to make use of this unallocated space on the SSD. This is done using gparted, by selecting the ext4 partition, selecting ‘Partition’, ‘Resize/Move Partition’, then resizing the ext4 partition to use all the unallocated space on the SSD.
