superduperHenry
ssh says at password all the time: "permission denied, please try later"
Fri Nov 03, 2017 6:38 pm
when I connect my raspberry pi to ssh and I want to ssh with my mac it says permission denied try, please try later. But I now my password sure. does someone know how to fix this
wh7qq
Re: ssh says at password all the time: "permission denied, please try later"
Fri Nov 03, 2017 8:35 pm
Several possibilities come to mind: Check your network connection...does your RPi show up on your router's device list? The default keyboard layout and language setting for the Raspbian OS is for the "UK" (or "GB"). Check that in /etc/default/keyboard, being sure that your settings are appropriate for your keyboard layout. If you did not place an empty file named "ssh" in the top directory of the boot partition (not the boot directory) and/or change your password and enable ssh in raspi-config, permission may be refused. Finally, when using wifi, if your network has encryption installed, the encryption key and SSID must be entered exactly as they are set on the router, including case. And of course, be certain that the Caps-Lock key is not set "on". All of these have bitten me on the tail at one time or another.
Sent by WH7QQ from an RPi3/Raspbian/pixel desktop.
superduperHenry
Sat Nov 04, 2017 5:29 pm
capsloch key is not turned on on my router (dreytek vigor2132 series) is not my raspberry pi and not my other divices. I turned my ethernet cable in LAN 1 and the ip for that is 192.168.1.1 so I put
ssh pi@192.168.1.1
but there happents nothing then.2
B.Goode
Sat Nov 04, 2017 6:01 pm
With a Draytek Vigor router ( and many other makes and models) the IP address 192.168.1.1 is very likely to be the address of the router itself.
superduperHenry
Sat Nov 04, 2017 6:22 pm
yes I know, but I turned my ethernet cable in my router on Lan port 1. The software says that the ip of port 1 is 192.168.1.1
DirkS
Sat Nov 04, 2017 6:29 pm
What software? Looks to me that you are looking at the IP of the router, as B.Goode suggested.
B.Goode
Sat Nov 04, 2017 6:35 pm
That's correct. The port is on the router. The IP address associated with that port, and therefore of the router, is 192.168.1.1 We appear to agree about that.
So using the IP address 192.168.1.1 will not be the correct way to make an SSH connection to your RPi.
superduperHenry
Sat Nov 04, 2017 7:05 pm
I put him just in Lan 3 and the ip from that port is 192.168.1.3 and he is doing nothing
superduperHenry
Sat Nov 04, 2017 7:07 pm
and if I put in my rpi
ifconfig
or
/sbin/ifconfig eth0
it says 168.254.246.64, when I put that ip adres nothing happents ether
B.Goode
Sat Nov 04, 2017 7:35 pm
When an RPi gets a 169.254.*.* Address it is an indication that it did not get a valid reply from a dhcp server so it defaults to that non-functional placeholder address instead.
That address cannot be used to communicate with your RPi over its router connection.
Have you rebooted the RPi after connecting it to the router?
Do you know that the utp network cable being used to connect the RPi to the router is in working order? Can any other device connect to that router port using the same cable?
superduperHenry
Sat Nov 04, 2017 9:39 pm
the software says that the Lan port is in use. I did reboot the RPI when I had it connected to the router. and he is connected right throw the port and it is in one cable. so it can't that input 1 is taking 2 cables
B.Goode
Sat Nov 04, 2017 10:25 pm
Clearly no other device can use the cable at the same time.
It will be necessary to remove the RPi and substitute another working device to check that the cable and port are functioning.
Gert van Loo
Mon Nov 06, 2017 1:04 pm
OK pretty stupid and basic but I have to ask: have you enabled ssh in the raspi-setup?
on4bgc
Tue Nov 07, 2017 6:33 pm
What's thé username of The Mac?
It must be pi
DirkS
Tue Nov 07, 2017 7:00 pm
It must be pi
Wrong.
Return to “Nederlands”
Who is online
Users browsing this forum: No registered users and 1 guest
