johndough
So far (again)
Sun Jan 26, 2014 1:56 pm
Hi
Yesterdays post got lost.
My Pi is now running the latest opensuse (dec 2013), it was done much the same as i would a NOOBS, using XP, and I have moved the partitions around as well.
I have a boot, swap, root and home on a 16 gig card.
ran zypper
zypper install joe
zypper in MozillaFirefox
zypper in yast*
and a few other things.
So I am here on my Pi and typing away using Firefox.
Still a lot to understand about all this.
more later.....
I broke it again.
Did find that
xzcat [image].raw.xz | dd bs=4M of=/dev/sdX; sync
seemed to prefer the line below
xzcat [image].raw.xz | dd bs=4MB of=/dev/sde; sync
johndough
Re: So far (again)
Mon Jan 27, 2014 11:02 am
Well that all went wrong.
So I redid the SD card and tried again, and that has all gone wrong.
Command line only.
Since I have been using SuSE from version 6.0 I hoped to be able to have my Pi and eat it arf arf.
Looks like I am going back to NOOBS.
remsnet
Contact: Website Yahoo Messenger
Re: So far (again)
Tue Feb 18, 2014 10:18 pm
johndough wrote:Well that all went wrong.
Command line only.
Well myself are still NOT use the OSS JePOS made Images , just due an simple reason : it required to resize the dos part to stubidly resize it from 200MB to 199MB to get it stable.
I am still use bernhards Widemans Images.
CorvusB
Re: So far (again)
Sun Apr 27, 2014 4:28 pm
I used Bernhard Weideman's latest image.
All command line to start - but clear and easy directions were found. Zypper in a bunch of stuff and all worked, mostly. One issue with an external SDD drive - covered in a different thread. But I'm pretty sure that this problem is not the OS, but the firmware updates.
Return to “openSUSE”
