remsnet
Contact: Website Yahoo Messenger
Yast2 , LXDE / KDE / IceWM - manual install - v0.2
Mon Feb 04, 2013 5:42 pm
Detailed Report how to get yast2 alive
- rewritten - v0.2 -
I used the betta Image raspberrypi-opensuse-20130110.img
An Rasperry from the perspektive of amount of ram avalible been an Thin Client.
There may been different User requirements ,
and allways have an THICK OpenSuSE may not the path all Users like to have.
I may asume that - It may not happen for the betta Images- to have Yast fully preinstalled
with X11 and i.e KDE in the same way as on x86 PC´s.
The image wuold be require at least an 4-6G sd card minimum for an uncompressed image with KDE.
For myself , the betta Images are enoth.
To get the current Image strategies changed, you may have to have asked the Open SuSE arm Team..
Myself don´t made the betta Images anyway - ask the Open SuSE ARM team.
Path to Install Yast2 maualy:
... well an to say so: ..NOR I´m from SuSE or work for them..
but , work with serval from / with SuSE since it exist as an IT Freelance Consultant.
Install Base Yast2 package:
# zypper install yast2
# zypper install yast2-online-update yast2-online-update-configuration yast2-online-update-frontend ncurses libyui-ncurses libyui-ncurses-pkg4
# zypper install yast2-inetd yast2-network yast2-storage yast2-sysconfig yast2-trans yast2-sudo yast2-sshd yast2-runlevel yast2-pam
# zypper install yast2-instserver yast2-installation yast2-ldap-client yast2-mail yast2-samba-server yast2-samba-client
check "Configured Software Repositories" and update them.
if "you" works , then the basic of Yast2 works.
# you
If you expect an LDXE , just install it i.e :
 # zypper search [b]lxde [/b]
# zypper install lxde-common lxde-common-branding-openSUSE patterns-openSUSE-lxde yast2-x11
Availbe Yast2 packages List
zypper search yast2 | egrep -v '(debuginfo|debugsource|devel|Quellpaket)'
If you Think you miss an Yast2 module , install it ...
Daten des Repositories laden ...
Installierte Pakete lesen ...
S | Name                                   | Zusammenfassung                                                 | Typ
  | autoyast2                              | YaST2 - Automated Installation                                  | Paket
  | autoyast2-installation                 | YaST2 - Auto Installation Modules                               | Paket
  | patterns-openSUSE-yast2_basis          | Meta package for pattern yast2_basis                            | Paket
  | patterns-openSUSE-yast2_install_wf     | Meta package for pattern yast2_install_wf                       | Paket
i | yast2                                  | YaST2 - Main Package                                            | Paket
  | yast2-add-on                           | YaST2 - Add-On media installation code                          | Paket
  | yast2-add-on-creator                   | YaST2 - module for creating Add-On product                      | Paket
  | yast2-all-packages                     | Internal Package                                                | Paket
  | yast2-apparmor                         | YaST2 - Plugins for AppArmor Profile Management                 | Paket
  | yast2-audit-laf                        | YaST2 - Configuration of Linux Auditing (LAF)                   | Paket
  | yast2-autofs                           | YaST2 - Module to Create and Manage autofs Entries in LDAP      | Paket
  | yast2-backup                           | YaST2 - System Backup                                           | Paket
  | yast2-bootloader                       | YaST2 - Bootloader Configuration                                | Paket
  | yast2-branding-SLED                    | YaST2 - SLED Branding                                           | Paket
  | yast2-branding-SLES                    | SLES branding for YaST                                          | Paket
  | yast2-branding-openSUSE                | openSuSE branding for YaST                                      | Paket
  | yast2-ca-management                    | YaST2 - CAs, Certificates and Requests Management               | Paket
  | yast2-control-center                   | YaST2 - Control Center                                          | Paket
  | yast2-control-center-gnome             | YaST2 - Control Center (GNOME version)                          | Paket
  | yast2-control-center-qt                | YaST2 - Control Center (Qt Version)                             | Paket
i | yast2-core                             | YaST2 - Core Libraries                                          | Paket
  | yast2-core-debugger                    | YaST2 - Core Libraries                                          | Paket
  | yast2-country                          | YaST2 - Country Settings (Language, Keyboard, and Timezone)     | Paket
  | yast2-country-data                     | YaST2 - Data files for Country settings                         | Paket
  | yast2-dbus-client                      | YaST2 - DBus Client Library                                     | Paket
  | yast2-dbus-server                      | YaST2 - DBus Server                                             | Paket
  | yast2-devtools                         | YaST2 - Development Tools                                       | Paket
  | yast2-dhcp-server                      | YaST2 - DHCP Server Configuration                               | Paket
  | yast2-dirinstall                       | YaST2 - Installation into Directory                             | Paket
  | yast2-dns-server                       | YaST2 - DNS Server Configuration                                | Paket
  | yast2-fcoe-client                      | YaST2 - Configuration of Fibre Channel over Ethernet            | Paket
  | yast2-fingerprint-reader               | YaST2 - Fingerprint Reader Configuration                        | Paket
  | yast2-firewall                         | YaST2 - Firewall Configuration                                  | Paket
  | yast2-firstboot                        | YaST2 - Initial System Configuration                            | Paket
  | yast2-ftp-server                       | YaST2 - FTP configuration                                       | Paket
i | yast2-hardware-detection               | YaST2 - Hardware Detection Interface                            | Paket
  | yast2-http-server                      | YaST2 - HTTP Server Configuration                               | Paket
  | yast2-inetd                            | YaST2 - Network Services Configuration                          | Paket
  | yast2-inetd-doc                        | YaST2 - Network Services Configuration                          | Paket
  | yast2-installation                     | YaST2 - Installation Parts                                      | Paket
  | yast2-instserver                       | YaST2 - Installation Server Configuration and Management        | Paket
  | yast2-irda                             | YaST2 - Infra-Red (IrDA) Access Configuration                   | Paket
  | yast2-iscsi-client                     | YaST2 - iSCSI Client Configuration                              | Paket
  | yast2-iscsi-server                     | YaST2 - Configuration of iSCSI target                           | Paket
  | yast2-isns                             | Configuration of isns                                           | Paket
  | yast2-kdump                            | Configuration of kdump                                          | Paket
  | yast2-kerberos-client                  | YaST2 - Kerberos Client Configuration                           | Paket
  | yast2-kerberos-server                  | YaST2 - Kerberos Server Configuration                           | Paket
  | yast2-ldap                             | YaST2 - LDAP Agent                                              | Paket
  | yast2-ldap-client                      | YaST2 - LDAP Client Configuration                               | Paket
  | yast2-ldap-server                      | YaST2 - OpenLDAP Server Configuration                           | Paket
  | yast2-live-installer                   | YaST2 - Installation from Live Media                            | Paket
  | yast2-lxc                              | Management tool for Linux Containers (LXC)                      | Paket
  | yast2-mail                             | YaST2 - Mail Configuration                                      | Paket
  | yast2-mail-plugins                     | YaST2 - Users/Group Plugins for the mail delivery configuration | Paket
  | yast2-metapackage-handler              | YaST2 - Easy Installation of Add-on RPMs using Metapackages     | Paket
  | yast2-mouse                            | YaST2 - Mouse Configuration                                     | Paket
  | yast2-multipath                        | YaST2 - Multipath Configuration                                 | Paket
  | yast2-network                          | YaST2 - Network Configuration                                   | Paket
  | yast2-nfs-client                       | YaST2 - NFS Configuration                                       | Paket
  | yast2-nfs-common                       | Configuration of NFS, common parts                              | Paket
  | yast2-nfs-server                       | YaST2 - NFS Server Configuration                                | Paket
  | yast2-nis-client                       | YaST2 - Network Information Services (NIS, YP) Configuration    | Paket
  | yast2-nis-server                       | YaST2 - Network Information Services (NIS) Server Configuration | Paket
  | yast2-ntp-client                       | YaST2 - NTP Client Configuration                                | Paket
  | yast2-online-update                    | YaST2 - Online Update (YOU)                                     | Paket
  | yast2-online-update-configuration      | Configuration of Online Update                                  | Paket
  | yast2-online-update-frontend           | YaST2 - Online Update (YOU)                                     | Paket
  | yast2-packager                         | YaST2 - Package Library                                         | Paket
  | yast2-packager-webpin                  | YaST2 - Webpin package search client                            | Paket
  | yast2-pam                              | YaST2 - PAM Agent                                               | Paket
i | yast2-perl-bindings                    | YaST2 - Perl Bindings                                           | Paket
  | yast2-phone-services                   | YaST2 - Phone Services Configuration                            | Paket
i | yast2-pkg-bindings                     | YaST2 - Package Manager Access                                  | Paket
  | yast2-power-management                 | YaST2 - Power Management Configuration                          | Paket
  | yast2-printer                          | YaST2 - Printer Configuration                                   | Paket
  | yast2-product-creator                  | YaST2 - Module for Creating New Products                        | Paket
  | yast2-profile-manager                  | YaST2 - Profile Configuration                                   | Paket
  | yast2-proxy                            | YaST2 - Proxy Configuration                                     | Paket
  | yast2-python-bindings                  | Python bindings for the YaST platform.                          | Paket
  | yast2-qt-branding-openSUSE             | openSUSE branding for yast2-qt                                  | Paket
  | yast2-reipl                            | YaST2 - IPL loader                                              | Paket
  | yast2-restore                          | YaST2 - System Restore                                          | Paket
  | yast2-ruby-bindings                    | Ruby bindings for the YaST platform                             | Paket
  | yast2-runlevel                         | YaST2 - Runlevel Editor                                         | Paket
  | yast2-samba-client                     | YaST2 - Samba Client Configuration                              | Paket
  | yast2-samba-server                     | YaST2 - Samba Server Configuration                              | Paket
  | yast2-scanner                          | YaST2 - Scanner Configuration                                   | Paket
  | yast2-security                         | YaST2 - Security Configuration                                  | Paket
  | yast2-slide-show-SLED                  | YaST2 - Slide Show (SUSE Linux Enterprise Desktop)              | Paket
  | yast2-slide-show-SLES                  | YaST2 - Slide Show (SUSE Linux Enterprise Server)               | Paket
  | yast2-slide-show-SuSELinux             | YaST2 - Slide Show (openSUSE)                                   | Paket
  | yast2-slp                              | YaST2 - SLP Agent and Browser                                   | Paket
  | yast2-slp-server                       | YaST2 SLP Daemon Server Configuration                           | Paket
  | yast2-snapper                          | YaST - file system snapshots review                             | Paket
  | yast2-squid                            | Configuration of squid                                          | Paket
  | yast2-sshd                             | YaST2 - SSH Server Configuration                                | Paket
  | yast2-storage                          | YaST2 - Storage Configuration                                   | Paket
  | yast2-sudo                             | YaST2 - sudo configuration                                      | Paket
  | yast2-support                          | YaST2 - Support Inquiries                                       | Paket
  | yast2-sysconfig                        | YaST2 - Sysconfig Editor                                        | Paket
  | yast2-testsuite                        | YaST2 - Testsuite                                               | Paket
  | yast2-tftp-server                      | YaST2 - TFTP Server Configuration                               | Paket
  | yast2-theme-SLE                        | YaST2 - SLE Theme                                               | Paket
  | yast2-theme-openSUSE                   | YaST2 - Theme (openSUSE)                                        | Paket
  | yast2-theme-openSUSE-Crystal           | YaST2 - Theme (openSUSE)                                        | Paket
  | yast2-theme-openSUSE-Oxygen            | YaST2 - Theme (openSUSE)                                        | Paket
  | yast2-trans                            | YaST2 - Translation Container Package                           | Paket
  | yast2-trans-af                         | YaST2 - Afrikaans Translations                                  | Paket
  | yast2-trans-allpacks                   | Internal: Require all YaST Translation Packages (Empty)         | Paket
  | yast2-trans-am                         | YaST2 - Amharic Translations                                    | Paket
  | yast2-trans-ar                         | YaST2 - Arabic Translations                                     | Paket
  | yast2-trans-ast                        | YaST2 - Asturian Translations                                   | Paket
  | yast2-trans-be                         | YaST2 - Byelorussian Translations                               | Paket
  | yast2-trans-bg                         | YaST2 - Bulgarian Translations                                  | Paket
  | yast2-trans-bn                         | YaST2 - Bengali Translations                                    | Paket
  | yast2-trans-bs                         | YaST2 - Bosnian Translations                                    | Paket
  | yast2-trans-ca                         | YaST2 - Catalan Translations                                    | Paket
  | yast2-trans-cs                         | YaST2 - Czech Translations                                      | Paket
  | yast2-trans-cy                         | YaST2 - Welsh Translations                                      | Paket
  | yast2-trans-da                         | YaST2 - Danish Translations                                     | Paket
  | yast2-trans-de                         | YaST2 - German Translations                                     | Paket
  | yast2-trans-el                         | YaST2 - Greek Translations                                      | Paket
  | yast2-trans-en_GB                      | YaST2 - British English Translations                            | Paket
  | yast2-trans-en_US                      | YaST2 - Translations                                            | Paket
  | yast2-trans-eo                         | YaST2 - Esperanto Translations                                  | Paket
  | yast2-trans-es                         | YaST2 - Spanish Translations                                    | Paket
  | yast2-trans-et                         | YaST2 - Estonian Translations                                   | Paket
  | yast2-trans-fa                         | YaST2 - Persian Translations                                    | Paket
  | yast2-trans-fi                         | YaST2 - Finnish Translations                                    | Paket
  | yast2-trans-fr                         | YaST2 - French Translations                                     | Paket
  | yast2-trans-gl                         | YaST2 - Galician Translations                                   | Paket
  | yast2-trans-gu                         | YaST2 - Gujarati Translations                                   | Paket
  | yast2-trans-he                         | YaST2 - Hebrew Translations                                     | Paket
  | yast2-trans-hi                         | YaST2 - Hindi Translations                                      | Paket
  | yast2-trans-hr                         | YaST2 - Croatian Translations                                   | Paket
  | yast2-trans-hu                         | YaST2 - Hungarian Translations                                  | Paket
  | yast2-trans-id                         | YaST2 - Indonesian Translations                                 | Paket
  | yast2-trans-it                         | YaST2 - Italian Translations                                    | Paket
  | yast2-trans-ja                         | YaST2 - Japanese Translations                                   | Paket
  | yast2-trans-jv                         | YaST2 - Javanese Translations                                   | Paket
  | yast2-trans-ka                         | YaST2 - Georgian Translations                                   | Paket
  | yast2-trans-km                         | YaST2 - Khmer Translations                                      | Paket
  | yast2-trans-kn                         | YaST2 - Kannada Translations                                    | Paket
  | yast2-trans-ko                         | YaST2 - Korean Translations                                     | Paket
  | yast2-trans-ku                         | YaST2 - Kurdish Translations                                    | Paket
  | yast2-trans-lo                         | YaST2 - Lao Translations                                        | Paket
  | yast2-trans-lt                         | YaST2 - Lithuanian Translations                                 | Paket
  | yast2-trans-mk                         | YaST2 - Macedonian Translations                                 | Paket
  | yast2-trans-mr                         | YaST2 - Marathi Translations                                    | Paket
  | yast2-trans-ms                         | YaST2 - Malay Translations                                      | Paket
  | yast2-trans-my                         | YaST2 - Burmese Translations                                    | Paket
  | yast2-trans-nb                         | YaST2 - Norwegian Bokmål Translations                           | Paket
  | yast2-trans-nds                        | YaST2 - Low Saxonian Translations                               | Paket
  | yast2-trans-nl                         | YaST2 - Dutch Translations                                      | Paket
  | yast2-trans-nn                         | YaST2 - Norwegian Nynorsk                                       | Paket
  | yast2-trans-pa                         | YaST2 - Punjabi Translations                                    | Paket
  | yast2-trans-pl                         | YaST2 - Polish Translations                                     | Paket
  | yast2-trans-pt                         | YaST2 - Portuguese Translations                                 | Paket
  | yast2-trans-pt_BR                      | YaST2 - Brazilian Portuguese Translations                       | Paket
  | yast2-trans-ro                         | YaST2 - Romanian Translations                                   | Paket
  | yast2-trans-ru                         | YaST2 - Russian Translations                                    | Paket
  | yast2-trans-si                         | YaST2 - Sinhala Translations                                    | Paket
  | yast2-trans-sk                         | YaST2 - Slovak Translations                                     | Paket
  | yast2-trans-sl                         | YaST2 - Slovene Translations                                    | Paket
  | yast2-trans-sr                         | YaST2 - Serbian Translations                                    | Paket
  | yast2-trans-stats                      | YaST2 - Translation Statistics                                  | Paket
  | yast2-trans-sv                         | YaST2 - Swedish Translations                                    | Paket
  | yast2-trans-sw                         | YaST2 - Swahili Translations                                    | Paket
  | yast2-trans-ta                         | YaST2 - Tamil Translations                                      | Paket
  | yast2-trans-tg                         | YaST2 - Tajik Translations                                      | Paket
  | yast2-trans-th                         | YaST2 - Thai Translations                                       | Paket
  | yast2-trans-tk                         | YaST2 -  Turkmen Translations                                   | Paket
  | yast2-trans-tr                         | YaST2 - Turkish Translations                                    | Paket
  | yast2-trans-uk                         | YaST2 - Ukrainian Translations                                  | Paket
  | yast2-trans-vi                         | YaST2 - Vietnamese Translations                                 | Paket
  | yast2-trans-wa                         | YaST2 - Walloon Translations                                    | Paket
  | yast2-trans-xh                         | YaST2 - Xhosa Translations                                      | Paket
  | yast2-trans-zh_CN                      | YaST2 - Simplified Chinese Translations                         | Paket
  | yast2-trans-zh_TW                      | YaST2 - Traditional Chinese Translations                        | Paket
  | yast2-trans-zu                         | YaST2 - Zulu Translations                                       | Paket
  | yast2-transfer                         | YaST2 - Agent for Various Transfer Protocols                    | Paket
  | yast2-tune                             | YaST2 - Hardware Tuning                                         | Paket
  | yast2-update                           | YaST2 - Update                                                  | Paket
  | yast2-update-FACTORY                   | YaST2 - Update                                                  | Paket
  | yast2-users                            | YaST2 - User and Group Configuration                            | Paket
  | yast2-wagon                            | YaST2 - Migration Tool for Service Packs                        | Paket
  | yast2-wagon-control-SLE                | YaST Wagon control file for SLE                                 | Paket
  | yast2-wagon-control-openSUSE           | YaST Wagon control file for openSUSE                            | Paket
  | yast2-x11                              | YaST2 - X11 support                                             | Paket
i | yast2-xml                              | YaST2 - XML Agent                                               | Paket
i | yast2-ycp-ui-bindings                  | YaST2 - YCP Bindings for the YaST2 User Interface Engine        | Paket
Hope this helps some "SuSE Newbies"
regards
Return to “openSUSE”
