remsnet
Contact: Website Yahoo Messenger
OpenSuSE 13.1 betta-test Images
Sat Feb 02, 2013 11:41 am
Hello Folks,
OpenSuSe Arm Team http://en.opensuse.org/Portal:ARM
released new PI 13.1 OpenSuSE http://en.opensuse.org/openSUSE:Raspberry_PiMilestone Image.
"Feel free to join the openSUSE ARM mailing list http://lists.opensuse.org/opensuse-arm/ as well as the #openSUSE-arm IRC [url]irc://irc.freenode.net/opensuse-arm[/url]channel for questions or help. We are also actively looking for people to enable hardware we don't support yet. If you have an armv7 based device that doesn't work yet and are willing to spend some time to get it working with openSUSE, please contact us on the mailing list. "
OpenSuSE Factory RPI Image Maintainer been : Bernhard M. Wiedemann
- Thanks Bernhard for you Excelence doing this... :D
OpenSuSE Images( Milestone 0 and later ) exist since arround Oktober 2012.
They are located at Berndards Images page at Location : http://zq1.de/~bernhard/linux/opensuse/
Orign Threads:
- http://www.raspberrypi.org/phpBB3/viewt ... SE#p276042
- http://forums.opensuse.org/iiiiiiiioe-g ... ry-pi.html ( greek OpenSuSE..)
Install : Same Way as other rasp Images , using DD or i.e w32diskimager
Linux DD Install i.e:
dd bs=1M if=raspberrypi-opensuse-20131206x.img of=/dev/sdb
Image Login :
user : root
passwd : linux
SD card resize :
- 1 remove swap sd card slice 2
# vi /etc/fstab, comment out the swap line
# swapoff /dev/mmcblk0p2
# fdisk  /dev/mmcblk0
d 2
w
- 2 resize root manualy
#  yast2
goto  system , partitioner
 ( see docu http://de.opensuse.org/YaST_Module_Partitionierer )
edit the  size to what you like .. i.e 10GB
# reboot
after relogin as root :
# resize2fs /dev/mmclk0p3
(see http://linux.die.net/man/8/resize2fs)
- 3 add swap 2GB
p
n
4
start cylinder +1 from the p2
end cylinder +?GB      , swap size you want i.e 2GB
w
# mkswap /dev/mmcblk0p4
# swapon /dev/mmcblk0p4
# vi /etc/fstab, comment in the swap line
Install vi or joe comandline editor
reason : Per default the Images sems are smal as possible.
zypper install vi
Install openssh
reason : Per default the Images sems are smal as possible. ...
zypper install openssh
Static Lan setup Manualy
Samples docu : http://www.novell.com/documentation/sus ... 14s03.html
without yast,
 you would edit :
1. /etc/sysconfig/network/ifcfg-eth0
BOOTPROTO='static'
IPADDR='192.168.0.123/24'
STARTMODE='auto'
2 .  vi /etc/sysconfig/network/routes
default 192.168.0.1 - -
3. vi /etc/resolv.conf
# enter here your dns from your router i.e
namesever 10.1.1.1
# enter here your domain
search net-dummy.org
4. vi /etc/hosts
# add i.e line
10.1.1.2 raspSuSE1.net-dummy.org raspSuSE1
5. vi /etc/hostname
Edit the hostname    must be the same as at /etc/hosts
/code]
[b]X11  & Video:[/b]
[code]
# for HDMI (1920x1080 for me) without black borders:
echo disable_overscan=1 > /boot/config.txt
# via http://elinux.org/RPi_config.txt
# This is how I got X11 working:
zypper in --no-recommends icewm xinit xauth xterm \
   xf86-video-fbdev xorg-x11-driver-input
 echo export WINDOWMANAGER=icewm > /etc/profile.d/windowmanager.sh
 # X defaults to vesa without this override:
 cat >/etc/X11/xorg.conf.d/50-device.conf <<EOF
Section "Device"
   Identifier "Default Device"
   Driver "fbdev"
 EndSection
 EOF
# reboot once
# startx
getting Yast2 to work :
 zypper install yast2-network yast2-ncurses yast2 lan
Opensuse Update:
Undertook a
zypper dist-upgrade
see at: http://en.opensuse.org/Portal:Zypper
Issues knownfrom test Images :
DO NOT Use SD cards bigger then 16GB , with kernel 3.1.10.x seems too old for that.
ps: Thanks to Eben to open this OS Folder
Spid
Re: OpenSuSE 12.3 betta-test Images
Sat Feb 02, 2013 2:24 pm
Great that it is all in one place. The issue I have is having a fully functioning YAST-GUI, a IceWM DE with more software pre-installed for newbies
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
dlachausse
Fri Feb 08, 2013 7:00 pm
Why such an old kernel? Is there a technical limitation requiring it?
The reason I ask is that I have a 32GB SD card that I want to try OpenSUSE on. When you say it won't work do you mean it won't work at all, or that it will treat it like a 16 GB card?
Thanks.
Spid
Fri Feb 08, 2013 7:22 pm
remsnet
Fri Feb 15, 2013 1:55 pm
dlachausse wrote:Why such an old kernel? Is there a technical limitation requiring it?
Thanks.
I had serveral SD card Corruped with use 32G / 64G Cards due the Old kernel.
Due that i stop trying that with the 3.1.x kernel - too expensive for my Project.
Thats why i wrote the warning currently not use bigger cards .
Maybe this changes with future releases , lets see what Bernhard may gives to with the next Images.
CoolApps
Mon Feb 18, 2013 5:21 pm
Thanks.
Try formating the corrupted cards to how they was before the corruption.
Android, web, linux, windows and scripting developer
Download Page: caftp.3owl.com
bmwiedemann
Wed Mar 13, 2013 9:55 am
please note that our armv5 repo has moved to
http://download.opensuse.org/ports/armv ... /repo/oss/
so you need to do
zypper rr OLDREPOID
zypper ar http://download.opensuse.org/ports/armv ... /repo/oss/ oss
until I find time to update my image accordingly
remsnet
Sat Apr 06, 2013 3:13 pm
That format the 32G / 64G card not help when an kernel driver Coorupts the Filesystem any time due missing SHDX kernel support at the opensuse 3.1.x kernel.
Debian and Fedora on the same card works - due has an patched kernel support for those SD cards+32GB.
Make an Diff of the .config from debian and suse kernels and you´ll see what i mean here.
Bernhard been hardy working to get the raspberrypi Image ready for the 3.6.11/3.7x kernel at Current.
The Current Image ( raspberrypi--20130401.img ) not fully ready yet for use.
It contains an few Easter Eggs
I.e mkinitrd failed fully with 3.6.11-0-raspberrypi and -3.7.6-2-versatile .
.. be fixed soo as he find time ..
EvgeniyMakhmudov
Mon Apr 15, 2013 7:14 am
Where is a correctly working image?
i found this openSUSE-Factory-ARM-JeOS-raspberrypi.armv7l-1.12.1-Build10.3.raw.xz and this raspberrypi-opensuse-20130401.img.gz but nothing working. With first image raspberry just don't boot, with the second nothing correct write to sd card.
remsnet
Mon Apr 15, 2013 6:51 pm
EvgeniyMakhmudov wrote:Where is a correctly working image?
Dear EvgeniyMakhmudov,
Please read the New Article : http://www.raspberrypi.org/phpBB3/viewt ... 53#p331953
This kernel hack FIXed the SHDC / SHDX kernel issues on OpenSuSE 12.3
Note :
I am Not Forum Admin for the OpenSuSE part , so i can NOT edit my own older Article.
forenbenutzer
Fri Jun 21, 2013 7:00 am
Any new versions here? I like yast and zypper more than apt-get. :]
Pitendo - Case And Emulator Project - http://edv-huber.com/index.php/problemloesungen/12-pitendo
remsnet
Fri Dec 20, 2013 7:07 pm
forenbenutzer wrote:Any new versions here? I like yast and zypper more than apt-get. :]
shure , at http://en.opensuse.org/HCL:Raspberry_Pi
and OpenSuSE pages as well : http://en.opensuse.org/openSUSE:Raspberry_Pi
Return to “openSUSE”
