sandrosart
Problems while installing openSUSE Leap 42.3
Tue Jan 02, 2018 7:27 pm
Hi everybody,
I'm relatively new to the raspberry board, and I need to install a 64-bit OS in order to program in ARM assembly. I decided to install the openSUSE Leap 42.3 version, following the instructions at this link: https://en.opensuse.org/HCL:Raspberry_Pi3 . When I connect the SD card and the USB key, it boots correctly and it gets to the GRUB, then after starting the installation, just after printing to the screen something like "Start udev", the board dies. I think it may be a psu problem, even if it works flawlessly with Raspbian OS. It should provide 5V @ 2.5A, the model is: HN-5258.
Does someone have ever experienced this problem and know how to solve it?
InoriHeart
Re: Problems while installing openSUSE Leap 42.3
Tue Feb 13, 2018 3:28 am
I have same problem in installing openSUSE Tumbleweed 20171125 20180208
Saiteja Kondisetty
Fri Oct 05, 2018 5:15 am
Extract Leap 42.3 image onto ur SDCard and remove all files except boot folder n then paste tumbleweed files except boot.efi file...then it works
Return to “openSUSE”
