Hi everybody,
I'm relatively new to the raspberry board, and I need to install a 64-bit OS in order to program in ARM assembly. I decided to install the openSUSE Leap 42.3 version, following the instructions at this link: https://en.opensuse.org/HCL:Raspberry_Pi3 . When I connect the SD card and the USB key, it boots correctly and it gets to the GRUB, then after starting the installation, just after printing to the screen something like "Start udev", the board dies. I think it may be a psu problem, even if it works flawlessly with Raspbian OS. It should provide 5V @ 2.5A, the model is: HN-5258.
Does someone have ever experienced this problem and know how to solve it?
