Reliable 64bit OS: Suse Linux Enterprise Server
Posted: Wed Nov 09, 2016 4:35 am
by ric96
https://www.suse.com/communities/blog/s ... pberry-pi/
I am just hoping they also have an OpenSuse counterpart.
Re: Reliable 64bit OS: Suse Linux Enterprise Server
Posted: Wed Nov 09, 2016 4:37 am
by ric96
Update: 64bit image is available for open suse.
https://en.opensuse.org/HCL:Raspberry_Pi3
Posted: Wed Nov 09, 2016 6:08 am
by Gavinmc42
Is this the first 64bit kernel released for Pi?
Want to try it but does not come as .img, it is raw ;)
Have to figure out how to write the SD from Windows.
Normally use Disk Imager.
Posted: Wed Nov 09, 2016 6:11 am
by ric96
Gavinmc42 wrote:Is this the first 64bit kernel released for Pi?
Not the absolute first, but definitely first stable and supported one.
In win32diskimager set show all file and select .raw
Posted: Wed Nov 09, 2016 6:33 am
by Gavinmc42
Rats did not work.
Did some boot and grub stuff then went blank :(
Will try with another SD card and yes it is a Pi3 ;)
Only a week to Leap.
We going to see Leap 42.1 Aarch64 released for Pi?
Rebooted a few times, USB keyboard not found......
Only 4.4.30 kernel?
I was expecting 4.8.?
Posted: Wed Nov 09, 2016 6:49 am
by Gavinmc42
Ok, maybe it is the server version that is 64bit, downloading now.
Posted: Wed Nov 09, 2016 7:33 am
by Gavinmc42
Working, took ages to install itself.
Have not used Suse before.
Up and running, kernel 4.4.21 but it is aarch64 :P
Posted: Sun Nov 13, 2016 3:54 pm
by pi-anazazi
Hi!
I prefer the images from this repo:
http://download.opensuse.org/repositori ... i3/images/
The manual for installation is here:
https://en.opensuse.org/HCL:Raspberry_P ... pstream.29
Or for Raspi 2B (ARM/) images and installation from here:
https://en.opensuse.org/HCL:Raspberry_Pi2
Posted: Tue Nov 15, 2016 1:09 am
by Rich Clemens
The download is a RAW file but just edit the name and remove the RAW and replace with img and it should work just fine. :)
Slow to install with rather impressive once loaded.
Rich
Posted: Tue Nov 15, 2016 5:10 am
by PeterO
ric96 wrote: Not the absolute first, but definitely first stable and supported one.
Hardly "supported"......
SUSE is not providing commercial support for SLES for the Raspberry Pi. Any questions should be posted to the Raspberry Pi forum at https://forums.suse.com/forum.php We will also provide a quick start guide to help new users set up SLES on the Raspberry Pi.
PeterO
Posted: Wed Nov 23, 2016 9:05 am
by fruitoftheloom
Posted: Wed Nov 23, 2016 12:00 pm
by pi-anazazi
Hi!
Has somebody been able to buy a new raspi 2b v1.2 with 2837 onboard? Can't find it yet...
Managed to get SLES to run on this machine?
Posted: Wed Nov 23, 2016 12:11 pm
by fruitoftheloom
pi-anazazi wrote:Hi!
https://cpc.farnell.com/raspberry-pi/rp ... model-b-v1
Posted: Wed Nov 23, 2016 12:20 pm
by RaTTuS
http://cpc.farnell.com/raspberry-pi/rpi ... dp/SC14210
Posted: Wed Nov 23, 2016 1:07 pm
by pi-anazazi
For delivery outside of the UK, including the Channel Islands, please contact our Export Coordinator at [email protected] or fax on 08447 880089.
Export orders cannot be processed on the website. All Export deliveries are subject to freight and restrictions.
Something a bit more "continental"? :-)
Posted: Wed Nov 23, 2016 1:14 pm
by fruitoftheloom
How the **** do we know where you reside, actually my crystal ball broke this morning from too much use :roll: :roll: :roll:
Posted: Wed Nov 23, 2016 1:17 pm
by jahboater
I've got one.
OpenSUZE did not work, I think it needs a Pi3.
Posted: Wed Nov 23, 2016 1:22 pm
by fruitoftheloom
I've got one.
Well that is stupid, it uses same BCM2837 SoC / Memory / Kernel / Firmware as a RPi 3B !!!!!
Posted: Wed Nov 23, 2016 1:38 pm
by ric96
I've got one.
I don't think the device tree its the same, maybe one could try replacing the dtb file with the one of the new pi2 and try.
Posted: Wed Nov 23, 2016 1:41 pm
by pi-anazazi
Hi fruity!
I learned recently that this is a family-friendly forum and we are not supposed to swear in such an environment. :-)
Regarding relevant location of Raspi 2B v1.2 dealer: Let's call it the EU (continental part of it...) :ugeek:
I looked in Germany and Sweden so far, with no success.
Posted: Wed Nov 23, 2016 1:46 pm
by RaTTuS
http://se.farnell.com/raspberry-pi/rpi2 ... dp/2612474
if you don't say where you'tr from in the location field then we have to assume somewhere
Posted: Wed Nov 23, 2016 2:05 pm
by pi-anazazi
Done! :-D
PS: Elements14 will only deliver to business customers, private users are referred to local dealer, which all I checked do not have the V1.2 in stock. But we are a little OT in the meantime. ;-)
