Luckily I broke the boot sequence for opensuse
Posted: Fri Jun 12, 2015 1:20 pm
Hi all
Well hour after hour of fruitless pi-ing.
Tried several versions and all give the following error on reboot
Net: Net Initialization Skipped
No ethernet found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-boot script /boot.scr
113 bytes read in 15ms (6.8 kb/s)
##Executing script at 00000000
2718 bytes read in 45ms (58.6kb/s)
##Executing script at 00000200
Switch to partitions #0, OK
##File not found boot/linux.vmx##
Script Failed: Continuing...
##Bad partition specification mmc 0:0:2##
##Error “bootcmd_firstboot” not defined##
U-Boot>
as I mentioned earlier.
However by tampering with the UEFI partition u-boot.bin I then get a different result...
A Rainbow rectangle, and onboard the RED LED shows and the GREEN LED flashes 7 times, then repeats. Which is a step in some direction, it might even be backwards.
So I assume that the Boot part with .elf files etc is either redundant or is bypassed.
Any theories anyone on the sequence or what I can try next.
Just to confirm that initial use gives a login and I can zypper in all sorts of stuff and on reboot FAILS each and time I re-image the card.
No ethernet found
Scanning mmc 0:1...
U-Boot>
