How do I resize the partition?
Posted: Thu May 29, 2014 2:29 pm
by RenePieters
I just installed the 2014-03-22 image, and things are looking great. However, I' ve got a 16 Gb card, and a 1.6 Gb image.
How do I go about resizing this? From the command line, as this machine is headless.
thanks for your attention,
Rene
Re: How do I resize the partition?
Posted: Thu May 29, 2014 6:28 pm
by JRV
If you are using Raspian, like this:
sudo raspi-config
Posted: Thu May 29, 2014 7:27 pm
by RenePieters
Ah.
The reason I asked this question in the NetBSD forum is because that is what I'm actually using. I doubt you can copy and paste that script from Raspbian to NetBSD. Will probably blow up big time.
kind regards,
Rene
Posted: Thu May 29, 2014 7:52 pm
by Joe Schmoe
BSD does everything weird - in terms of the disk partitioning, right?
IIRC, it uses slices and stuff like that instead of the regular stuff that Linux uses. So, no, it probably wouldn't port, nor would the advice to do it manually - the way we used to do it before there was a raspi-config - be likely to work either.
You'll probably have to re-invent it all. But it shouldn't be *that* hard, I guess.
Posted: Thu May 29, 2014 8:05 pm
by MrEngman
You could try a search on Google using "resize netbsd partition"
MrEngman
Posted: Thu May 29, 2014 8:43 pm
by RenePieters
Would you be surprised if I told you I already did?
But let me humour you.
https://duckduckgo.com/?q=resize+netbsd ... =canonical
Not much, mostly FreeBSD. And I do not know how relevant that is.
I did find this, however: http://wiki.netbsd.org/ports/evbarm/raspberry_pi/
Anyone care to comment as to relevance and accuracy? Is there no better way?
Rene
