cureshut
FreeBSD booting b+ but not booting a+ with same sd card
Fri Jan 09, 2015 8:20 pm
Hi all,
i installed freebsd to sd card. b+ version raspberry pi boots up but a+ is not booting with same card
any suggests?
thanks
mahjongg
Re: FreeBSD booting b+ but not booting a+ with same sd card
Fri Jan 09, 2015 10:05 pm
Not enough ram on an A+?
cureshut
Fri Jan 09, 2015 10:09 pm
maybe can i configure freebsd for 256 mb ram?
mahjongg
Fri Jan 09, 2015 10:14 pm
You can try changing the memory split, standard the A+ ARM only gets half, or 128MB.
see config.txt (if freebsd uses it, I have no idea).
Return to “FreeBSD”
