lucdig
Portsnap - first run - squid
Thu Nov 13, 2014 5:33 pm
Hello, I compiled successfully squid with
make install clean
in the /user/ports/www/squid directory. The tool showed me a very useful menu to set the options (SSL, SSL_CRTD, etc etc).
When I tried to compile again (I need squid with different options) with the same command as above, the graphical tool does not appear..... Why?
What can I do to achieve the graphical tool to appear again?
Thank you very much
raymod2
Re: Portsnap - first run - squid
Thu Nov 13, 2014 6:08 pm
Run "make rmconfig" to remove the configuration options you selected previously. For more information about using ports:
https://www.freebsd.org/doc/handbook/ports-using.html
lucdig
Thu Nov 13, 2014 7:54 pm
Thank you.
I've googled it and find that the options are stored in /var/db/ports/www_squid directory.
Removing www_squid directory, allow me to set options with the graphical tool.
Regards
Return to “FreeBSD”
