balanga
Unable to build any ports
Sat Aug 23, 2014 8:26 pm
Has anyone successfully built any port on a Raspberry Pi?
I've tried a few but get lots of errors which I don't understand and can't help wondering if I've missed something...
When building a port is there normally a buildlog so that I have a record of any error messages generated?
I would love to install midnight commander, as I'm really lost without it.
mahjongg
Re: Unable to build any ports
Sat Aug 23, 2014 9:42 pm
what do you mean by "build a port"?
to me it sounds like you want to dig a big hole for ships to sail into!
as for midnight commander, simple!
sudo apt-get install mc
balanga
Sun Aug 24, 2014 12:39 am
mahjongg wrote:what do you mean by "build a port"?
Does that work on FreeBSD?
I presumed that FreeBSD was the topic here, but I'm new here so maybe I'm mistaken...
Sun Aug 24, 2014 5:09 am
No that response was for Raspbian Wheez,y FreeBSD is different as it is Unix not Linux
RTM http://www.freebsd.org/doc/en_US.ISO885 ... ports.html
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
mahjongg
Sun Aug 24, 2014 1:11 pm
balanga wrote: Does that work on FreeBSD?
your OP contains no mention of FreeBSD, so I assumed you were talking about the default OS Raspbian.
Didn't see I was in the FreeBSD section..... :?
So by "port" I assume you mean a port of freeBSD for the PI?
i feel silly now! :oops:
sorry! :roll:
Bakul Shah
Wed Aug 27, 2014 7:04 am
balanga wrote:Has anyone successfully built any port on a Raspberry Pi?
You may wish to ask on the [email protected] mailing list as that is where people who are capable of helping you hang out. You may wish to run the latest stable binary from ftp://ftp.freebsd.org/pub/FreeBSD/snaps ... AGES/10.0/. AFAIK this is still quite a moving target and more recent kernel/userland may yield better results. Also see http://www.cruwe.de/?p=78 if you want to build things under Qemu.
seedymac
Mon Sep 01, 2014 8:14 pm
I was able to build a port, but it took like 6 hours.
I am using FreeBSD 11, after booting up successfully you need to install the source files for the ports collection.
1-portsnap fetch
2-portsnap extract
These two commands take a long time on the RPI, when the last one completes, You will have a fresh /usr/ports directory.
The port that I have installed is bzip2.
-cd /usr/ports/archivers/bzip2
-make install
This took a long time, bzip2 has lots of dependencies, Perl is one of them and binutils.
Note: I have mounted a USB drive on /usr/ports
Filesystem Size Used Avail Capacity Mounted on
/dev/mmcsd0s2a 14G 625M 13G 5% /
devfs 1.0K 1.0K 0B 100% /dev
/dev/mmcsd0s1 17M 3.4M 14M 20% /boot/msdos
/dev/da0b 6.3G 906M 4.9G 15% /usr/ports
/dev/md0 29M 24K 26M 0% /tmp
/dev/md1 14M 56K 13M 0% /var/log
/dev/md2 4.4M 8.0K 4.0M 0% /var/tmp
liyize926
Thu Sep 04, 2014 12:42 pm
My system is FreeBSD 10.
Did you have installed ports collection?
you can use these commands to install it;
# portsnap fetch update
# portsnap  extract
if this step failed,the wrong message is"set your clock correctly...";the reason is RasPI doesn't has a time-of-day clock,you must setup your system time to the right time. you can use these commands.
# ntpdate 202.120.2.101
Because of the low frequency of RasPI ,it will take about 8hrs...
then you can install whatever you like.
here is an example which you can find in FreeBSD Handbook Chap5.5.This example install the lsof.
eg.
# cd /usr/ports/sysutils/lsof
# make
# make install
# make clean
At the first time I install minicom by using ports collection, I used the commands as follow:
# make install clean
but it failed,i didn't know why, then I installed it step by step -----make then install then clean,and it woks.
Hope these can help you.
Return to “FreeBSD”
