michele.x
FreeBSD and config.txt
Sun Aug 03, 2014 2:02 pm
Hello all.
I've just tried to install a FreeBSD snapshot, FreeBSD-11.0-CURRENT-arm-armv6-RPI-B-20140701-r268111.img to be precise and I've notice that the overscan parameters on config.txt aren't used. Other parameters are read correctly (for instance sdtv_mode or sdtv_disable_colourburst. Is this normal?
This is the config.txt I've used: the video parameters are the same used on a working linux sdcard.
disable_overscan=0
overscan_top=16
overscan_bottom=16
overscan_left=16
overscan_right=0
sdtv_mode=2
sdtv_aspect=1
sdtv_disable_colourburst=0
hdmi_force_hotplug=0
disable_commandline_tags=1
gpu_mem=32
device_tree=rpi.dtb
device_tree_address=0x100
kernel=uboot.img
Quibly
Re: FreeBSD and config.txt
Tue Aug 02, 2016 3:56 pm
it worked for me but with strange result and only when using large numbers ie. 700
Finally I found this solution:
overscan_scale=1
and then things fell into place
Return to “FreeBSD”
Who is online
Users browsing this forum: No registered users and 2 guests
