Vctrsnts
Version for RPI 2 ( 1.1 )
Mon May 21, 2018 2:24 pm
Hi.
I'm doing tests to put freeBSD to the RPI 2 (1.1), but I have doubts when selecting the image that I have to download for the RPI.
I mention it, because when reading the FreeBSD wiki, you can see the following:
The Raspberry Pi 2 released in February 2015 has 4 USB ports, micro SD slot, a new 900 MHz quad-core ARM Cortex-A7 CPU, 1GB RAM and complete compatibility with Raspberry Pi 1.
From what I understand, the RPI is compatible with the RPI 2. That means I have to download the RPI-B image or it's the RPI-2 image
Thank you if you can clarify this doubt.
Re: Version for RPI 2 ( 1.1 )
Tue May 22, 2018 7:38 am
Hi.
FreeBSD 12 cutrent for RPi2:
https://www.freebsd.org/where.html
Retired disgracefully.....
Vctrsnts
Tue May 22, 2018 2:38 pm
Thanks a lot.
And why this version? :o
Tue May 22, 2018 6:12 pm
Thanks a lot.
Seems like "current" means "stable" ??
nes_pi
Mon Jun 25, 2018 1:52 am
Is the RPI-B version for 3 b+ too? OpenBSD fan here but dont mind using freebsd if its for the pi.... :D
Return to “FreeBSD”
