Lina
FreeBSD auto-cpu scalling
Sat Aug 22, 2015 3:36 pm
Hey !
Actually there is no automatic cpu scalling on FreeBSD ARM. So your CPU frequency will always be at 600 Mhz. As you can see :
dev.cpu.0.freq_levels: 900/-1 600/-1
dev.cpu.0.freq: 600
Of course you can set manually your CPU to 900 Mhz by doing :
# sysctl dev.cpu.0.freq=900
But I don't want to have a 900 Mhz CPU all the time. So I created a python script which will check the load average every 10 seconds and scale the frequency when needed.
You can download it here : http://lina.devio.us/pycpuscalefbsdpi.py
To launch it at system startup :
# crontab -e
@reboot /your/path/to/python /your/path/pycpuscalefbsdpi.py > /dev/null 2>&1
http://blog.cagedmonster.net/ - Geek / Unix / Linux / Raspberry
Lina
Re: FreeBSD auto-cpu scalling for RPI2
Sun Aug 23, 2015 1:12 pm
UPDATE : I updated the script so it can directly read dev.cpu.0.freq_levels values. It means the script will work with every version of Raspberry PI or if you have an overclocked Raspberry PI.
Psypro
Wed Dec 16, 2015 5:55 pm
This works.
But if I want it to work every reboot?
I tried adding it to /etc/sysctl_conf, that had no effect as far as i could tell with a :
[email protected]:/home/freebsd # sysctl dev.cpu.0
dev.cpu.0.temperature: 45.5C
dev.cpu.0.freq: 600
dev.cpu.0.%parent: cpulist0
dev.cpu.0.%pnpinfo: [email protected] compat=arm,cortex-a7
dev.cpu.0.%location:
dev.cpu.0.%driver: cpu
dev.cpu.0.%desc: Open Firmware CPU
hornpipe2
Sat Dec 10, 2016 6:54 pm
This should be unnecessary... you should instead use the powerd daemon to control dynamic frequency scaling.
Edit /etc/rc.conf:
powerd_enable="YES"
Then restart the daemon:
/etc/rc.d/powerd restart
Or just reboot the Pi. sysctl -a shows these values for my (overclocked) machine:
dev.cpu.0.freq_levels: 1000/-1 900/-1 800/-1 700/-1 600/-1 500/-1 400/-1 300/-1
dev.cpu.0.freq: 1000
Return to “FreeBSD”
