TomMadeO
Unable to locate package pistore
Sun Dec 30, 2012 1:28 am
I have tried loading the store but keep getting this:
E:Unable to locate package pistore
any clue where i am going wrong?
[email protected] ~ $ sudo apt-get update && sudo apt-get install pistore
Hit http://archive.raspberrypi.org wheezy InRelease
Ign http://archive.qmh-project.org unstable InRelease
Ign http://archive.qmh-project.org unstable Release.gpg
Hit http://http.debian.net wheezy InRelease
Ign http://archive.qmh-project.org unstable/main armel Packages/DiffIndex
Hit http://archive.raspberrypi.org wheezy/main armel Packages
Hit http://http.debian.net wheezy/main armel Packages/DiffIndex
Hit http://http.debian.net wheezy/contrib armel Packages/DiffIndex
Hit http://archive.qmh-project.org unstable/main armel Packages
Hit http://http.debian.net wheezy/non-free Translation-en/DiffIndex
Hit http://http.debian.net wheezy/contrib Translation-en/DiffIndex
Hit http://http.debian.net wheezy/non-free armel Packages/DiffIndex
Ign http://archive.qmh-project.org unstable/main Translation-en_GB
Hit http://http.debian.net wheezy/main Translation-en/DiffIndex
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Reading package lists... Done
Building dependency tree
E: Unable to locate package pistore
-t
TomMadeO
http://www.flickr.com/photos/tommadeo
Pankoi
Re: Unable to locate package pistore
Sun Dec 30, 2012 1:41 am
Hi there!
From the apt-get update output, it looks as if you have a soft float (denoted by the 'armel' in the repositories it's checking) OS? You'll need a Raspbian version which uses hard float (armhf) - the Pi Store isn't present in the armel repositories.
Hope that helps,
~Richard Williams
Edit: There's more information in this topic. :)
The Pi Store: the home of games, apps, tutorials and other content for Raspberry Pi - store.raspberrypi.com
Want to hear about new Pi Store content? Follow @PiStoreReleases on Twitter.
TomMadeO
Sun Dec 30, 2012 1:56 am
Thanks for that.
I guess I can stop trying to get it to load now!!!
What are the advantages/ disadvantages of a soft or hard float? Or should I just read the wiki???
Thanks for the patience everyone. New to Linux here.
-t
TomMadeO
ghans
Sun Dec 30, 2012 12:01 pm
You should only keep soft-float if you need
1) Java from Oracle
2) Mono
3) Squeezeplug
Else , i strongly suggest switching to hard-float , because
it is top priority to the foundation , gets the most updates and improvements
and is faster .
ghans
burdebc
Mon Feb 15, 2016 7:58 am
I am unable to install the pi store. Earlier today I downloaded noobs lite and let it download rasbpian, and I have made no changes beyond that. Below is what I get from the terminal when I execute the command to install. Any help is greatly appreciated.
[email protected]:~ $ sudo apt-get update && sudo apt-get install pistore
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Hit http://mirrordirector.raspbian.org jessie InRelease
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
DirkS
Mon Feb 15, 2016 10:52 am
The Pi store is dead (and has been for quite a while now)
See viewtopic.php?f=83&t=130379
