epsilon5
Re: Introducing the Pi Store!
Sat Dec 29, 2012 2:02 am
Brilliant idea.
Hope you get lots of support.
stinkiydot
Mon Dec 31, 2012 9:38 am
Thank you :)
dbasberg
Pi Store install failed
Mon Dec 31, 2012 11:57 pm
I see someone had the install fail and went back to square one - blank SD. My install failed the first time. I shutdown and removed power, then I rebooted and used 'sudo apt-get install pistore'. I watched it proceed and noticed it added new packages and had no errors. I entered 'pistore' in an lxterminal window and I was up and running. Before starting over on configuring the whole O/S, you might want to try this less drastic approach.
Hope that helps
Doug
Five RPIs: 2:256 & 2:512 and an RPI3 used for monitor and control in out buildings of farm (embedded controls). Linux/Python novice. Experienced real-time programmer/hardware/systems designer (asm, C, C++).
Michael777
Wed Jan 09, 2013 2:09 am
I like Pi
[code][code][code][code][code][code][list][i][list=][list=][list=][list=][list=][list=][CENTER][URL=http://www.nodiatis.com/personality.htm][IMG]http://www.nodiatis.com/pub/4.jpg[/IMG][/URL][/CENTER][/list][/list][/list][/list][/list][/list][/i][/list]
[/code][/code][/code][/code][/code][/code]
Wed Jan 09, 2013 10:10 am
Michael777 wrote:I like Pi
I like Trains.
Please direct all questions to the forum, I do not do support via PM.
WeUsePis
Wed Jan 09, 2013 12:37 pm
Sheldon?
Our Pi Blog - http://weusepis.wordpress.com/
swinster
Sat Jan 19, 2013 10:10 pm
I seem to have a similar error
/usr/bin/pistore: line 16: /home/pi/indiecity/pistore/Scripts.log: No such file or directory
/usr/bin/pistore: line 29: /home/pi/indiecity/pistore/Scripts.log: No such file or directory
Pi Store would like your permission to create an 'indiecity' group on this Pi. You may have to enter your sudo password.
tee: /home/pi/indiecity/pistore/Scripts.log: No such file or directory
addgroup: The group `indiecity' already exists.
ERROR: Could not add indiecity group.
/usr/bin/pistore: line 41: /home/pi/indiecity/pistore/Scripts.log: No such file or directory
This is a pretty fresh install, did try and update, but came back with the result the 'pistore' was up to date. Will try a cold reboot to see what occurs.
swinster
Sat Jan 19, 2013 10:59 pm
Slight addendum to the above, I am actually running the 'Pistore" app under a different user account (edited the code above to show the 'Pi' user).
Logged on as the Pi user and all looks OK.
Is this supposed to work like this or should all users be able to access the store, or is there additional config required for other users?
Pankoi
Tue Jan 22, 2013 11:54 pm
Hi there!
Yeah, Pi Store should work with all users. If the user account is not a member of the indiecity group, then it will try to add it when you start Pi Store for the first time.
Unfortunately, there's an error with our script logging system (which is what you're seeing), but this will be fixed in the next update which should be out soon. Alternatively, you can call "mkdir -p $HOME/indiecity/pistore" and this should allow you to proceed. :)
Hope that helps,
~Richard Williams
The Pi Store: the home of games, apps, tutorials and other content for Raspberry Pi - store.raspberrypi.com
Want to hear about new Pi Store content? Follow @PiStoreReleases on Twitter.
Pankoi
Thu Jan 24, 2013 11:21 am
Hi again,
The update I mentioned is now out. Please let me know if you have any more problems with it. :)
~Richard Williams
BadHistory
Wed Apr 10, 2013 3:34 pm
This is basically like apples AppStore or Google Chrome's "Market" Where we can upload games, applications and other things for the RPi and for the RPi only?
DrPiD
Wed Apr 10, 2013 3:41 pm
BadHistory wrote:This is basically like apples AppStore or Google Chrome's "Market" Where we can upload games, applications and other things for the RPi and for the RPi only?
Yes, a very similar idea :)
Community Manager - IndieCity
breaker
Mon May 06, 2013 9:08 am
Hi, the Pi Store comes with the latest Raspbian, bravo. However I clicked download on something (after I registered), then it shows a list of my library or whatever it is called (I forgot exactly, I'm on a PC atm)... but there is nothing listed there, and if it downloaded a book to the Pi, I don't know where it is.
Does downloading work for you?
poodle448
Contact: Yahoo Messenger AOL
Sat Jul 13, 2013 8:57 am
Very awesome! I am looking forward to my pi, I just got it today - I have a 1TB external Hard Drive I will be using for my pi; I can't wait! :D
-Ryan
sdisbrow
Sun Jan 12, 2014 12:17 am
Hi, I'm blind and was wondering if there is a command way of using the pistore, either from the pi or from a webpage on another computer?
Pankoi
Sun Jan 12, 2014 12:50 am
You should just be able to type 'pistore' into a terminal window on a Pi, if that's any help to you. There's no default hotkey set-up though, or anything of that kind. What sort of mechanism would you find most useful?
~Richard Williams
seitzdeb987
Thu Aug 07, 2014 2:49 am
Where in Canada can I find Pi store? I wanted to avail one.
texy
Thu Aug 07, 2014 6:52 am
seitzdeb987 wrote:Where in Canada can I find Pi store? I wanted to avail one.
Anywhere where you can get internet access - it is an online shop only.
Texy
DirkS
Thu Aug 07, 2014 11:47 am
Pi store does not sell hardware; see http://www.raspberrypi.org/introducing-the-pi-store/
scruss
Thu Aug 07, 2014 12:32 pm
Depends where you are. Lots of mail order (like Newark), and in person in places like Sayal (a bit expensive) or Creatron (two locations in Toronto; the owner now works out of the store on Sheppard Ave, and is most helpful in picking out the stuff you need).
You know that the Molson Canada "Canada Day" national-anthem-recognizing beer fridge used a Raspberry Pi? Here's what they did: The Beer Fridge - O Canada | Behind the Scenes | Molson Canadian - YouTube
tarkadelphis
Fri Nov 20, 2015 5:36 pm
Hi, I have tried to install pistore to Raspbian Jessie. This fails with
E: Unable to locate package pistore
- Any ideas why this fails or is this a temporary missing link on the server?
Mike
Fri Nov 20, 2015 8:55 pm
tarkadelphis wrote:Hi, I have tried to install pistore to Raspbian Jessie. This fails with
Mike
PiStore died January 2015 :shock:
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
geechy
Just found out about Raspberry Pi
Fri Dec 25, 2015 7:04 am
Where does one buy a Raspberry Pi and then where does one find support as a newbie?
Re: Just found out about Raspberry Pi
Fri Dec 25, 2015 7:21 am
geechy wrote:Where does one buy a Raspberry Pi and then where does one find support as a newbie?
Lots of places.
Check out the Products page for links https://www.raspberrypi.org/products/
You can find support here on the forums, on the Help pages https://www.raspberrypi.org/help/, in the Pi Community pages https://www.raspberrypi.org/community/
Return to “The Pi Store”
Who is online
Users browsing this forum: No registered users and 1 guest
