watchdogが起動できない
Posted: Sat Jul 21, 2018 2:54 am
by isonbo
ラズパイ3でraspbian9.4を使っています。
watchdogを動かそうとしているのですが、
$ sudo systemctl start watchdog
のコマンドを入力すると、いつまでも帰ってきません。
ちなみに
$ sudo systemctl status watchdog
の出力は
● watchdog.service - watchdog daemon
Loaded: loaded (/lib/systemd/system/watchdog.service; enabled; vendor preset: enabled)
Active: inactive (dead)
となっています。
どなたか解決方法またはチャック項目を知っていれば教えて下さい。
Re: watchdogが起動できない
Posted: Fri Dec 21, 2018 2:08 am
by doublehp
Can't speak chineese, but I found a solution to this bug.
I had this bug on Ubuntu on Orange Pi zero.
The bug is explained here:
https://bugs.launchpad.net/ubuntu/+sour ... ug/1448924
https://bugzilla.redhat.com/show_bug.cgi?id=1259816
I did not have it on this machine:
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.3 LTS
Release:        16.04
Codename:       xenial
but I have it here:
# lsb_release -a
Description:    Ubuntu 16.04.5 LTS
Release:        16.04
Codename:       xenial
The solution was:
echo "WantedBy=default.target" >> /lib/systemd/system/watchdog.service
systemctl daemon-reload
systemctl enable watchdog
reboot
# wait 2 mn, because it needs to reboot twice.
Before the fix:
# systemctl status watchdog.service
â watchdog.service - watchdog daemon
   Loaded: loaded (/lib/systemd/system/watchdog.service; static; vendor preset: enabled)
After:
   Active: active (running) since Fri 2018-12-21 03:02:14 CET; 58s ago
  Process: 1122 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS)
  Process: 1120 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS)
 Main PID: 1126 (watchdog)
   CGroup: /system.slice/watchdog.service
           ââ1126 /usr/sbin/watchdog
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: int=1s realtime=yes sync=no soft=no mla=5 mem=0
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: ping: no machine to check
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: file: /var/log/syslog:0
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: pidfile: no server process to check
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: interface: no interface to check
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: temperature: maximum = 80
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: temperature: /sys/class/thermal/thermal_zone0/temp
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: test=none(0) repair=none(0) alive=/dev/watchdog heartbeat=none to=...ce=no
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: watchdog now set to 10 seconds
Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: hardware watchdog identity: sunxi-wdt
Hint: Some lines were ellipsized, use -l to show in full.
Re: watchdogが起動できない
Posted: Tue Dec 25, 2018 2:22 pm
by masafumi_ohta
ちなみに
の出力は
となっています。
太田です。すいません、かなり多忙にてチェックが遅れました。
このあたり確認されてますか?
viewtopic.php?t=147501
太田
Re: watchdogが起動できない
Posted: Tue Dec 25, 2018 2:23 pm
by masafumi_ohta
Thanks information doublehp it is Japanese pages not Chinese :-)
