raspdroid
Provided arguments to Remote VM
Wed Jan 14, 2015 11:25 pm
I use these arguments to use the rxtxSerial library in Raspberry Pi :
java -Djava.library.path=/usr/lib/jni/ -jar application.jar
But how to do it in Remote VM?
I tried so:
--remote-classpath
/usr/lib/jni
192.168.1.50:8998
application.Main
But not work to me. I get this exception:
INFO: [/dev/ttyAMA0 - 9600/8/N/1/N] Opening the connection interface...
java.lang.UnsatisfiedLinkError: no rxtxSerial in java.library.path thrown while loading gnu.io.RXTXCommDriver
What is the right way?
Best regards
raspdroid
Re: Provided arguments to Remote VM
Thu Jan 15, 2015 11:21 am
I cleaned all arguments of the project.
In Build Path > Configure > Libraries > select rxtx-2.2.jar > + > select native library location > Edit > and add /usr/lib/jni
I use this code to see java.library.path in Main application (JavaFX).
 static {
		 String property = System.getProperty("java.library.path");
		 StringTokenizer parser = new StringTokenizer(property, ";");
		 while (parser.hasMoreTokens()) {
		     System.err.println(parser.nextToken());
Running in LocalHost is all correct:
/usr/lib/jni
INFORMACIÓN: [/dev/ttyAMA0 - 9600/8/N/1/N] Opening the connection interface...
WARNING:  RXTX Version mismatch
	Jar version = RXTX-2.2pre1
	native lib Version = RXTX-2.2pre2
In RemoteHost (Raspberry Pi) I added this in run configurations but the path to jni directory not appears:
--remote-classpath
/usr/lib/jni
192.168.1.50:8998
application.Main
/usr/java/packages/lib/arm:/lib:/usr/lib
PD: At the moment I resolved so:
cd /usr/lib
sudo ln -s /jni/librxtxSerial.so .
Jan 15, 2015 11:24:27 AM com.digi.xbee.api.XBeeDevice open
clicky
Fri Jan 16, 2015 8:51 am
Sorry to kept you waiting and your question is quite valid. Yes, it seems that I had similar problem and I have solved it but forgot to update usage output of client jar.
Anyway you need to use --remote-VM-argument or -rvma followed by argument passed to each newly started VM (by remote agent, of course).
So, something like:
192.168.1.50:8998
application.Main
Right now I am not next to my RPi so I can double check it, but will do it later.
On slightly different subject - I have been doing what you are very recently and adopted slightly different approach: avoided RxTx library provided directly on Pi but embedded one in resulting code (jar) itself. That way I don't care if it is installed or Pi or not. Even better, same code can smartly decide to use different .so file and work on Linux. Or OSX! (I've covered both). And, after all, Windows, too!
Have a quick look at: https://github.com/natdan/rbx-toolset/t ... obox/comms
Send me a PM if you are interested to go further with it, as it would be nice to make little open source project to allow such multi-platform access to RxTx library. Or at least to refine solution I've done so far...
raspdroid
Tue Jan 20, 2015 9:49 pm
Sorry, I have not been able to test it before.
Works well with -rvma
Thank you very much!.
Best regards
Return to “Java”
