Robbi_Blechdose
Java IDE?
Sat Sep 27, 2014 6:48 pm
On my PC,
I work with eclipse to program java. But it doesn't seem to work on my Pi (I just have the splash screen from eclipse for 5 minutes, then I close it because that's too long to wait). Now, is there any IDE I can use to program in Java? It should at least be capable of showing syntax errors, coloring my code (like eclipse) and it should have a button or something else to start my program. And it should take no longer than 1 minute to start.
Btw, I have the oracle java "thingy" from the post/whatever on raspberrypi.org installed.
Robbi Blechdose
kusti8
Re: Java IDE?
Sat Sep 27, 2014 7:48 pm
Robbi_Blechdose
Re: Java IDE?
Sun Sep 28, 2014 6:14 am
Thank you.
So Geany would work with the Java version I "described" earlier?
Robbi Blechdose
kusti8
Re: Java IDE?
Sun Sep 28, 2014 11:39 pm
Yes,it should.
clicky
Re: Java IDE?
Fri Oct 03, 2014 9:08 am
Why don't you use comfort of a PC or Laptop and Eclipse on it to develop with RPi?
There are a few posts about it here. My preferable way is described here http://www.raspberrypi.org/forums/viewt ... 90#p495190 but you can go with http://www.raspberrypi.org/forums/viewt ... 81&t=71660 which you can adopt for Eclipse, IntelliJ or similar, too.
RemoteVM (http://remotevm.abstracthorizon.org/) is designed for you to have all RPi stuff developed and compiled in any IDE on PC/Laptop and then seamlessly run on RPi. If you start it from shell from X-Windows (or alternative!) it will be able to display all graphical stuff, too. Thing I wanted to do but real life prevented me (read lack of spare time) was to write up using LibGDX with RemoteVM on RPi. It worked like a charm! :)
zeddex
Re: Java IDE?
Sat Oct 18, 2014 7:18 pm
JBerries is a simple Java IDE for the Raspberry PI:
http://sourceforge.net/projects/jberries/
Here's my original introduction:
http://www.raspberrypi.org/forums/viewt ... 81&t=65974
User guide is here:
http://jberries.sourceforge.net/index.html
Return to “Java”
