ArnavKumar
How to play Mp3 and Mp4 using Java?
Tue Nov 05, 2013 10:38 am
Is there any open source for java to play Mp3 or Mp4 using my java code?
xranby
Re: How to play Mp3 and Mp4 using Java?
Thu Nov 07, 2013 12:00 pm
There is no mp3 decoder found in the Java JRE thus you need to use a third party project that at least enable mp3 & mp4 decoding.
JLayer is a java decode for mp3 files.
http://www.javazoom.net/javalayer/javalayer.html
You need to combine JLayer with your own audio output in order to create a mp3 player.
Example here JLayer is used to create a tiny java mp3 player applet:
appletviewer http://www.javazoom.net/applets/tinypla ... layer.html
The JogAmp JOGL and JOAL project provides a GLMediaPlayer class can decode and playback both mp3 and mp4 files, GLMediaPlayer uses the system installed libav/libffmpeg library’s to do the mp3 & mp4 decoding
mp4 video is rendered using OpenGL ES and
decoded mp3 audio is sent to the pi sound-card using OpenAL.
http://jogamp.org/
Example usage of JogAmp GLMediaPlayer using one of the examples found inside the jogl-test.jar
java -cp joal.jar:jogl-test.jar:gluegen-rt.jar:jogl-all.jar com.jogamp.opengl.test.junit.jogl.demos.es2.av.MovieCube -url file:///home/pi/test.mp3
More examples on how to setup and use JogAmp from the command line on the pi:
https://gist.github.com/xranby/55de4fd65bfadae26203
It is also possible to make Java start a command line tool that both display video and do audio playback like omxplayer (mp4 video), mpg321 (mp3 audio), vlc (mp3 & mp4) command line tools using System.getRuntime().exec()
http://docs.oracle.com/javase/7/docs/ap ... .String%29
For example the JavaFX DukePad uses mpg321 under the hood to playback mp3 files
https://wiki.openjdk.java.net/display/OpenJFX/DukePad
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
ArnavKumar
Sat Nov 09, 2013 8:48 am
xranby wrote:There is no mp3 decoder found in the Java JRE thus you need to use a third party project that at least enable mp3 & mp4 decoding.
http://jogamp.org/
Thank you very much for your help
TechKnow Heights
sirkope
Tue Nov 12, 2013 7:28 am
xranby wrote: For example the JavaFX DukePad uses mpg321 under the hood to playback mp3 files
Could you compile DukePad sources?
I've tried to follow the wiki page you mentioned, but I failed (like a few of us here :http://www.raspberrypi.org/phpBB3/viewt ... it=dukepad)
xranby
Tue Nov 12, 2013 2:51 pm
Yes I am able to compile the Duke Pad sources. I have update the thread you linked with further instructions.
twitter.com/xranby
ArnavKumar
Tue Nov 19, 2013 12:35 pm
One can use "Java Media Framework (JMF)" for creating video player and mp3 player in java.
xranby
Wed Nov 20, 2013 9:32 am
ArnavKumar wrote:
ArnavKumar wrote:Is there any open source for java to play Mp3 or Mp4 using my java code?
Please note that JMF is not available under a free software license, the Sun Community Source Licensing lacks essential freedoms such as publication of modified versions.
http://www.oracle.com/technetwork/java/ ... #jmfsource
One alternative is FMJ that implements the same API compared to JMF under a free software license, LGPL.
http://fmj-sf.net/
Both variants need recompilation of its native code before they can be used on ARM Linux systems such as the Pi.
twitter.com/xranby
henrik
Fri Dec 06, 2013 7:21 pm
More importantly, JMF is old and not maintained. I would not recommend using it. Starting with JavaFX/OpenJFX and the DukePad sources (GPL, BSD) seems like a better idea.
Henrik Stahl
Oracle Java team
Return to “Java”
