RoyLongbottom
JRE For Applet Hard Float
Sun May 26, 2013 9:05 pm
On the Pi I have JRE 6, 7 and 8 installed and JDK 7 to compile class files. I have the Java Whetstone benchmark (floating point) with both off-line and on-line versions. I switch between the Javas using sudo update-alternatives --config java. The off-line benchmark runs using all Java JREs but needs JRE 8 Hard Float for reasonably fast speeds.
The on-line Applet always uses JRE 6, whatever JRE is selected. How can I select a different JRE for Midori and will it use hard float?
Googling suggests solutions but there is invariably a specified command that is not valid. The Whetstone Applet is available via:
http://www.roylongbottom.org.uk/online%20benchmarks.htm
A poor score shows MFLOPS less than 8 and a good one >20 (off-line 26 to 49).
Roy
xranby
Re: JRE For Applet Hard Float
Mon May 27, 2013 10:51 am
RoyLongbottom wrote:...
The on-line Applet always uses JRE 6, whatever JRE is selected. How can I select a different JRE for Midori and will it use hard float?...
Midori can be used in combination with the IcedTea-web plugin on Debian & Rasbian by installing the icedtea-plugin or icedtea-7-plugin package.
http://icedtea.classpath.org/wiki/IcedTea-Web
http://packages.debian.org/source/sid/icedtea-web
icedtea-plugin / icedtea-6-plugin is using OpenJDK 6 that includes 3 JVM
Zero, JamVM and CACAO
You can configure which JVM to be used by default for OpenJDK 6 by editing /etc/java-6-openjdk/jvm-armhf.cfg
icedtea-7-plugin is using OpenJDK 7 that includes 2 JVM
Zero and JamVM
You can configure which JVM to be used by default by editing /etc/java-7-openjdk/jvm-armhf.cfg
All the JVM's listed above "will use hard float" and runs on Rasbian.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
RoyLongbottom
Mon May 27, 2013 5:23 pm
Thanks xranby
It took a while to find how to edit the files (sudo pico filename, insert -jamvm KNOWN as first line, save by Ctrl O). I can’t remember how I edited such files the last time I played with Linux.
Anyway hard float now works on JRE 6 and JRE 7 off-line. Midori also uses hard float but only seems to use Java 1.6. Results follow, showing JRE 7 a little faster than JRE 8, JRE 8 a lot faster but far behind the C version.
Old JRE6 and 7
 Test                  Result       MFLOPS     MOPS  millisecs
  N1 floating point  -1.124750137      4.39             4.3700
  N2 floating point  -1.131330609      6.35            21.1700
  N3 if then else     1.000000000               2.93   35.2700
  N4 fixed point     12.000000000               7.94   39.6500
  N5 sin,cos etc.     0.499110103               0.99   83.9300
  N6 floating point   0.999999821      3.32           162.3700
  N7 assignments      3.000000000               2.51   73.5600
  N8 exp,sqrt etc.    0.751108646               0.30  125.3100
  MWIPS                               18.33           545.6300
  Java Vendor         Sun Microsystems Inc., Version  1.6.0_27
  N1 floating point  -1.124750137      9.41             2.0400
  N2 floating point  -1.131330609     10.01            13.4300
  N3 if then else     1.000000000               8.14   12.7200
  N4 fixed point     12.000000000              17.84   17.6600
  N5 sin,cos etc.     0.499110103               0.69  121.4300
  N6 floating point   0.999999821      8.91            60.5200
  N7 assignments      3.000000000               5.35   34.5700
  N8 exp,sqrt etc.    0.751108646               0.23  164.7500
  MWIPS                               23.41           427.1200
  Java Vendor         Oracle Corporation, Version  1.7.0_07
  N1 floating point  -1.124750137     12.32             1.5580
  N2 floating point  -1.131330609     11.73            11.4600
  N3 if then else     1.000000000              10.89    9.5080
  N4 fixed point     12.000000000              23.60   13.3500
  N5 sin,cos etc.     0.499110103               0.74  112.9900
  N6 floating point   0.999999821      9.73            55.4400
  N7 assignments      3.000000000               6.16   30.0100
  N8 exp,sqrt etc.    0.751108646               0.24  154.2600
  MWIPS                               25.73           388.5760
  Java Vendor         Oracle Corporation, Version  1.8.0-ea
  N1 floating point  -1.124750137     49.18             0.3904
  N2 floating point  -1.131330490     46.54             2.8880
  N3 if then else     1.000000000              27.73    3.7320
  N4 fixed point     12.000000000              92.48    3.4060
  N5 sin,cos etc.     0.499110103               1.08   77.3100
  N6 floating point   0.999999821     26.69            20.2100
  N7 assignments      3.000000000              39.90    4.6320
  N8 exp,sqrt etc.    0.751108646               0.31  119.9300
  MWIPS                               43.01           232.4984
Whetstone Single Precision C Benchmark  Opt 3 32 Bit, Wed May 15 16:41:59 2013
Loop content                   Result              MFLOPS      MOPS   Seconds
N1 floating point      -1.12475013732910156        97.811               0.053
N2 floating point      -1.12274742126464844       100.800               0.360
N3 if then else         1.00000000000000000                 698.625     0.040
N4 fixed point         12.00000000000000000                 425.250     0.200
N5 sin,cos etc.         0.49911010265350342                   5.850     3.840
N6 floating point       0.99999982118606567        85.669               1.700
N7 assignments          3.00000000000000000                 498.960     0.100
N8 exp,sqrt etc.        0.75110864639282227                   2.722     3.690
MWIPS                                             270.460               9.983
Roy
Return to “Java”
