Lightweight Java HTTP Async Server
Posted: Sun Apr 28, 2013 2:58 pm
by bullen
Try this server: rupy
It's faster and uses less memory, also it has HTTP hot-deploy that is seamless for uninterrupted multiuser development and unnoticeable live deployments = no downtime.
It uses NIO, so it scales and can do real time comet long-poll chat and streaming!
Finally when you finished your app there's really cheap rpi cluster hosting: host.rupy.se
Re: Lightweight Java HTTP app server
Posted: Sun Jun 09, 2013 10:18 pm
by bullen
Just released version 1.0
Posted: Tue Nov 25, 2014 10:26 am
by bullen
Now you can build your own HTTP server cluster on many RPi's with this. It also has a cluster NoSQL database!
We have a cheap PaaS ready for deployment, but you can easily build your own too!
Posted: Tue Nov 25, 2014 2:00 pm
by auron89
how can I install on raspberry and make a deploy?
Posted: Tue Dec 23, 2014 7:17 pm
by bullen
Tutorial, if you have a problem I can answer your specific question.
Posted: Thu Dec 25, 2014 1:08 pm
by clicky
I was a bit sceptical but it really seems very light and with small footprint. I'll try to use it for my next project (instead of built in server).
Posted: Sun Feb 08, 2015 10:24 am
by bullen
Did a benchmark of the rupy cometstream and 6x it is. Almost the same performance as an old atom or a new NUC, but per watt it dominates!
Comet Stream
6.500 messages per joule!!! That might just be some kind of world record! ;)
Edit: I'm just blown away by this figure. The next best per watt is the Intel NUC, which costs 500$ (including memory and SSD) compared to the RPi2 which costs 45$ including SD card. So the RPi2 costs 1000% less to buy and 700% less to power for 70% of the performance. I was about to retire my RPi plans for an all Intel setup, but now I will use one passively cooled Intel NUC as loadbalancer for a cluster of RPi2 per node.
Posted: Sat Feb 14, 2015 10:52 am
by bullen
Now I have added so that you can hot-deploy to your pi with rupy on projects that use a COM port integration to increase development speed of all your Java hardware projects.
Install RXTX on your pi:
sudo apt-get install librxtx-java
Example code:
public class Router extends Daemon.Com {
	static Daemon daemon;
	static Router router;
	private static InputStream in;
	private static OutputStream out;
	public Router(String tty) {
		try {
			System.setProperty("gnu.io.rxtx.SerialPorts", tty);
			CommPortIdentifier id = CommPortIdentifier.getPortIdentifier(tty);
			if(id.isCurrentlyOwned()) {
				System.out.println("Error: Port is currently in use.");
			} else {
				CommPort port = id.open("COM", 1000);
				if(port instanceof SerialPort) {
					SerialPort serial = (SerialPort) port;
					serial.setSerialPortParams(9600,
							SerialPort.DATABITS_8,
							SerialPort.STOPBITS_1,
							SerialPort.PARITY_NONE);
					in = serial.getInputStream();
					out = serial.getOutputStream();
					Thread thread = new Thread(new Reader(in));
					thread.start();
				else {
					System.out.println("Error: Only serial ports are handled by this example.");
		catch(Exception e) {
			e.printStackTrace();
	public static class Send extends Service {
		Receiver rec;
		public String path() { return "/"; }
		public void create(Daemon daemon) {
			rec = new Receiver(daemon);
			daemon.com().set(rec);
		public void filter(Event event) throws Event, Exception {
			System.out.println(event.query().header());
			if(event.query().method() == Query.POST) {
				event.query().parse();
				String message = event.query().string("message");
				event.daemon().com().write(message.getBytes());
	public static class Receiver implements Daemon.Listen {
		StringBuilder builder = new StringBuilder();
		Daemon daemon;
		public Receiver(Daemon daemon) {
			this.daemon = daemon;
		public void read(byte[] data, int length) throws Exception {
			String in = new String(data, 0, length);
			System.out.println(in);
	public void write(byte[] data) throws IOException {
		out.write(data);
	public static class Reader implements Runnable {
		InputStream in;
		public Reader(InputStream in) {
			this.in = in;
		public void run() {
			byte[] data = new byte[1024];
			int length = -1;
			try {
				while((length = this.in.read(data)) > -1) {
					try {
						router.listen.read(data, length);
			} catch(Exception e) {
	public static void main(String[] args) {
		daemon = Daemon.init(args);
		router = new Router("/dev/ttyAMA0");
		daemon.set(router);
		daemon.start();
Then you need to add the hot-deployed jar to the classpath and run Router instead of Daemon:
java -Djava.library.path=/usr/lib/jni -classpath /usr/share/java/RXTXcomm.jar:http.jar:app/your-app.jar Router -pass XXXXXX
Re: Lightweight Java HTTP Async Server
Posted: Fri May 29, 2015 8:03 am
by bullen
Now the RPi 2 cluster is online on host.rupy.se:
http://monitor.rupy.se
Here you can insert database entries across the entire cluster: http://root.rupy.se
Posted: Sun Mar 27, 2016 6:50 pm
by bullen
Now I have built a multiplayer engine on top of this:
https://github.com/tinspin/fuse
Has both Javascript HTML5 and Unity C# clients!
Also I built a forum module:
http://talk.binarytask.com
