ulde
Soft-float Debian wheezy, Oracle Java SE 7 and Hynix RAM
Thu Mar 21, 2013 8:33 am
I use the Soft-float Debian wheezy image (2012-08-08-wheezy-armel) to run Oracle Java SE Embedded version 7 Update 10 (7u10) on 512MB Pi boards.
Now I understand that some of the newest boards are built with Hynix RAM chips, requiring an updated image, like the latest Raspbian wheezy (2013-02-09-wheezy-raspbian), that I can't use because Java SE wouldn't work on it.
Does anyone have experience installing the old Soft-float Debian wheezy image on 512MB Pi boards with the Hynix RAM chip?
xranby
Re: Soft-float Debian wheezy, Oracle Java SE 7 and Hynix RAM
Thu Mar 21, 2013 12:11 pm
Most kernel developers are focusing on improving the new armhf Rasbian, it will give you a more stable drivers for use on your Pi and will work with the latest Hynix RAM chips. Also Oracles latest ARM JVM only work on Rasbian.
I recommend you to switch to Rasbian and try the Java SE compatible versions that are available:
http://www.raspberrypi.org/phpBB3/viewt ... 81&t=27805 - Status of java on Raspbian.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
malakai
Thu Mar 21, 2013 12:19 pm
I am only aware of the issue affecting RISC OS but haven't followed the issue on the soft float. I believe the warning was removed from RISC because they fixed it. Mostly it's a trial and error. If your posting in response to http://www.raspberrypi.org/archives/3534 I think you can kind of read it that before returning your Pi try an official image. It will save everyone a headache. But there can be other issues with the other OS's and any hardware compatibility not just the RAM.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
jojopi
Thu Mar 21, 2013 12:32 pm
Provided you have at least one older Pi, you can boot the soft float image and run "sudo apt-get update && sudo apt-get upgrade". That will install the latest stable firmware, and the card should then work fine on Hynix boards.
ulde
Thu Mar 21, 2013 12:33 pm
xranby wrote:Most kernel developers are focusing on improving the new armhf Rasbian, it will give you a more stable drivers for use on your Pi and will work with the latest Hynix RAM chips. Also Oracles latest ARM JVM only work on Rasbian.
Thanks for your rely,
I need to use the Oracle Java 7 SE, and that is only available on soft float, afaik. Oracle JDK 8 for ARM Early Access is indeed supporting armhf, but that is still prerelease.
Thu Mar 21, 2013 12:45 pm
I *think* you can take start.elf from the latest release and use that on the softfloat distro. Make a backup of the original in case it doesn't work!
jorabo
Thu Mar 21, 2013 1:05 pm
i tested the oracle jdk8 pre-release for arm hf and it works fine and fast !
kungfujam
Sun May 19, 2013 4:18 pm
So I've just spent a good few hours trying to boot the Soft-float Debian “wheezy” from:
http://www.raspberrypi.org/downloads
so that I can run a package that doesn't work on the Hard-float Raspian image.
The image did not boot as it was downloaded. It worked only after I stole 3 files from the Raspian image:
bootcode.bin
fixup.dat
start.elf
I dumped them on the sd with the Soft-float Debian image and it booted fine.
http://elinux.org/R-Pi_Troubleshooting# ... on_display
Return to “Java”
