posi90
RXTX - CommPortIdentifier
Sun Feb 03, 2013 12:10 pm
I want to create a serial connection between raspberry pi and arduino due.
My problem is that CommPortIdentifier.getPortIdentifier(portName) throws an expression:
My code:
		CommPortIdentifier portIdentifier = CommPortIdentifier
				.getPortIdentifier(portName);
This is the errorcode:
gnu.io.NoSuchPortException
        at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:269)
        at main.connect(main.java:17)
        at main.main(main.java:129)
The function CommPortIdentifier.getPortIdentifiers(); does not list any ports.
The code is running fine on windows. Are there any permissions or releases due to /dev/ttyAMA0 to define?
The funny thing is that minicom and gtkterm work even without su i just cant get it work for java.
KG
Poseidon
ramp
Re: RXTX - CommPortIdentifier
Mon Feb 11, 2013 1:35 pm
Try this command:
sudo ln -s /dev/ttyAMA0 /dev/ttyS80
and use ttyS80, other option is pi4j for work directly with ttyAMA0
http://pi4j.com/example/serial.html
i tested sucessfully pi4j for communicate raspi and arduino.
Note: Sorry for my english :P
Return to “Java”
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
