Mon Jan 28, 2013 3:38 pm
I am using Debian “Wheezy”
JRE: java version "1.7.0_10"
Java(TM) SE Embedded Runtime Environment (build 1.7.0_10-b18, headless)
Java HotSpot(TM) Embedded Client VM (build 23.6-b04, mixed mode)
Java programs run great , MySQL is installed and working great.
for some reason the distribution (done with tomcat+servlet communication to mysql) does not work
the problematic part is the mysql connection part.
BTW this installation works great on other server deployment , but not on the Raspberry
any ideas why?
Mon Jan 28, 2013 4:25 pm
Please post the java exception you get.
Most likely you need to install the MySQL JDBC Driver
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
Return to “Java”
Who is online
Users browsing this forum: No registered users and 7 guests
