atael
Reading temp using MCP3800
Sun Jan 27, 2013 5:19 am
I am trying to write a Java (SE 7 Embedded u10) program that reads temperature from a Analog Temp Sensor TMP36 (http://www.adafruit.com/products/165) using a MCP3800 ADC (https://www.adafruit.com/products/856).
In order to read analog data I need to use the following pins I think (outside of GND 3.3V):
  • DOUT (Data Out from MCP3008)
    CLK (Clock pin)
    DIN (Data In from Raspberry Pi),
    CS (Chip Select).
I've connected the MCP3800 like this:
  • VDD -> 3.3V
    VREF -> 3.3V
    AGND -> GND
    CLK -> #18
    DOUT -> #23
    DIN -> #24
    CS -> #25
    DGND -> GND
My thought is to have the
  • Pin #18 (CLK) as a GPIO Out Pin
    Pin #23 (DOUT) as a GPIO In Pin
    Pin #24 (DIN) as a GPIO Out Pin
    Pin #25 (CS) as a GPIO Out Pin
and the TM36 like this:
  • pin1 -> 3.3V
    pin2: analog out --> channel0 on mcp3008 (pin1)
    pin3: GND
And I am struggling (not sure what I am doing) but I would guess that I need to access the GPIO ports using java.io,RandomAccessFile (or java.nio.FIle) but I am short of knowledge on how to accomplish this. I am pretty sure part of my failure is that I am not sure I understand the Pi and the GPIO ports in full yet.
I have googled and binged around but can't fins any examples, so maybe someone on this forum has an idea on how to get me started?
Andy
savageautomate
Re: Reading temp using MCP3800
Wed Jan 30, 2013 2:46 am
Hi Andy,
I don't have an example on hand, but I would suggest using a library such as Pi4J that provides access to the SPI communication bus.
https://github.com/Pi4J/pi4j/blob/maste ... i/Spi.java
(This class is a JNI wrapper around the SPI implementation in the WiringPi native library)
-Robert.
Robert Savage | Follow me @savageautomate
http://www.pi4j.com | http://www.pislices.com
http://www.savagehomeautomation.com
OlivierLD
Tue Jan 28, 2014 10:13 pm
Hi Andy,
Not sure it is not too late, but just in case, I did something similar. It's not with a thermometer, it's with a potentiometer.
The Java source is available at https://code.google.com/p/raspberry-pi4j-samples/, the doc at http://www.lediouris.net/RaspberryPI/ADC/readme.html.
Cheers,
- Olivier
Return to “Java”
