david_rubrecht_1
Folders of /opt/pi4j do not exist
Tue Jan 01, 2013 5:36 am
After extensive effort in running one single java file, I eventually reached the step of compiling a file. But then upon reading the steps of pi4j's guide http://pi4j.com/install.html, i realized that i must compile with the class file from pi4j's library. But it does not exist.
I do not understand what I am doing wrong, as I am folowing the exact steps from the link above and yet I cannot ever seem to attain those folders of /opt/pi4j.
I also tried making them myself before installing the package, and that did not work
savageautomate
Re: Folders of /opt/pi4j do not exist
Tue Jan 01, 2013 11:53 pm
There is a defect in the current installer package that will fail in some cases if the scripts cannot create or remove the expected folders:
Try the steps listed here to see if you can get a clean install of Pi4J:
https://github.com/Pi4J/pi4j/issues/25# ... t-11766950
Thanks, Robert
Robert Savage | Follow me @savageautomate
http://www.pi4j.com | http://www.pislices.com
http://www.savagehomeautomation.com
savageautomate
Wed Jan 02, 2013 12:31 am
If you need it, here are manual instruction to get Pi4J on your Pi:
https://groups.google.com/d/topic/pi4j/ ... discussion
Return to “Java”
