BennoDev
RaspberryPi 4 with Java 13.0.1
Sun Nov 17, 2019 9:29 am
Does anybody know how I can install Java 13.0.1 on a RaspberryPi 4?
Because I use Java 13.0.1 on my WindowsEngine and so I wrote and exported my JavaApplication with Java 13.0.1 but the RaspberryPi only supports a lincenced Version of Java 11.0.5 which is not available for free :/ If there is no way to install the 13.0.1 Java on the Pi .. I think I have to switch on both (windows and Raspbian) devices to Java 8 :C
I tried many ways to install Java 13.0.1 to the PI but it will not run :C
Thank you :)
https://stackoverflow.com/questions/588 ... ava-13-0-1
Re: RaspberryPi 4 with Java 13.0.1
Sun Nov 17, 2019 12:15 pm
Thank you :)
openjdk 11.0.5 is in the Raspbian Buster repositories.....
https://packages.debian.org/buster/openjdk-11-jdk
Asus ChromeBox 3 Celeron is my other computer.
oicfar
Sat Nov 30, 2019 10:00 pm
Thank you :)
https://adoptopenjdk.net/releases.html? ... nt=hotspot
Return to “Java”
