fredand44
[SOLVED] Java3D - Available GLVersions not set for EGLGraphicsDevice
Thu Oct 17, 2019 5:05 am
Hello guys,
I have an old project that uses Java3D. It is a java app that renders some 3D graphics.
But when I start it on my Raspberry PI 4 with OS Raspbian I get this error:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/home/albin/H%c3%a4mtningar/object3Dcreator-app-1.0.0-jar-with-dependencies.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Exception in thread "AWT-EventQueue-0" java.lang.InternalError: Available GLVersions not set for EGLGraphicsDevice[type .egl, v1.4.0, connection decon, unitID 0, handle 0x7b3030, owner true, NullToolkitLock[obj 0x1a66d50]]
at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1952)
at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875)
at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1842)
at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230)
at java.base/java.security.AccessController.doPrivileged(Native Method)
Could there be some settings in Raspbian that enable GLVersions or do I need to install some packages to enable it?
Best regards
Fredrik
fredand44
[SOLVED ]Re: Java3D - Available GLVersions not set for EGLGraphicsDevice
Fri Oct 25, 2019 6:06 am
Hello Guys,
I got some java3d help at this place:
http://forum.jogamp.org/Available-GLVer ... 40111.html
Best regards
Fredrik
clicky
Fri Oct 25, 2019 8:14 am
Thanks for sharing link back to JOGL. That was helpful! :)
fredand44
Mon Oct 26, 2020 11:40 am
I did some summary, perhaps this helps someone.
http://forum.jogamp.org/Available-GLVer ... l#a4040853
Best regards
Fredrik
Return to “Java”
