Method in ArrayList?
Posted: Fri Sep 27, 2019 9:53 pm
by Zilla707
Hello, I have done some java, but I mostly do python3, and in python3 you can add a function to a list:
>>> def test():
print('Test')
>>> testList = []
>>> testList.append(test)
>>> testList[0]()
Test
So my question is: is there a way to do this, (or something like it), in java?
Re: Method in ArrayList?
Posted: Sat Sep 28, 2019 10:29 am
by clicky
Java is very versatile object oriented language that can do many things and falls in very similar category as Python.
So, answer is: yes.
All you have to do now is to learn it. Internet is full of resources, examples and sites where you can even learn it online, do online courses and such.
Posted: Sat Sep 28, 2019 11:15 pm
by knute
It's a little more complicated in Java.
import java.util.*;
import java.util.function.*;
public class SSCCE { // simple self contained compilable example
public static void main(String... args) {
// returns the argument unchanged
UnaryOperator<String> u1 = UnaryOperator.identity();
// returns the argument changed to lower case
UnaryOperator<String> u2 = String::toLowerCase;
// returns the argument's characters reversed
UnaryOperator<String> u3 = f -> {
return new StringBuffer(f).reverse().toString();
// returns the argument's characters reversed and then to lower case
Function<String,String> u4 = u3.andThen(u2); // or .compose
// creates a list to hold functions
List<Function<String,String>> list = new ArrayList<>();
// add the functions to the list
list.add(u1);
list.add(u2);
list.add(u3);
list.add(u4);
// apply the functions to the arguments
System.out.print(list.get(0).apply("Hello"));
System.out.println(list.get(1).apply(" WORLD!"));
System.out.println(list.get(2).apply("SRETTEL EHT ESREVER"));
System.out.println(list.get(3).apply(
"ESAC REWOL OT SRETTEL EHT ESREVER"));
C:\Users\Knute>java SSCCE.java
Hello world!
REVERSE THE LETTERS
reverse the letters to lower case
Posted: Sun Sep 29, 2019 10:31 pm
by Zilla707
Thanks, I still don't know very much about java, (at least in relation to python), but that's very helpful.
Posted: Sat Nov 30, 2019 12:39 pm
by DamienIvy
What I can understand you want to append a value to the List using python code.
In Java , you can append the value to the ArrayList using add() method of ArrayList class.
ArrayList<String> arrlist = new ArrayList<String>();
arrlist.add("test");
System.out.println(arrlist);
Reference:
https://javahungry.blogspot.com/2017/10 ... ample.html
Posted: Mon Mar 23, 2020 7:50 am
by aryank4564
This is a pretty clear example of how to add data to ArrayList in python. However, if you want to learn how to append data into the ArrayList in Java. Just see the below code
ArrayList<String> arrayList = new ArrayList<>();
arrayList.add("Object 1");
arrayList.add("Object 2");
System.out.println(arrayList);
See Reference :
https://www.java8net.com/2020/02/arraylist-in-java.html
Posted: Wed Feb 17, 2021 9:27 am
by anmoldhiman
You can use add() method of ArrayList
' List<String> list = new ArrayList<String>();
list.add("shivam");
You can visit ArrayList examples
https://www.javavogue.com/2015/05/java- ... ples.html/
https://www.javavogue.com/2015/05/how-t ... java.html/
