calucio24
Problem with 500 Hz signal detection interrupt with PI4J [solved]
Thu Apr 18, 2019 9:44 am
Hi guys, this is Carlo.
I'm developing a java application with pi4j 1.1 and raspberry pi zero w. I have external hardware that sends to a raspberry a square signal at 500Hz.
My problem is that with interrupt I don't detect any pin edge event variation. Instead, if I read a signal in a loop cycle I can read that the signal is low and then high.
My interrupt code is this:
InputOutputManager.getInstance().getSpi_cs().addListener(new GpioPinListenerDigital() {
            @Override
            public void handleGpioPinDigitalStateChangeEvent(GpioPinDigitalStateChangeEvent event) {
                  if(event.getEdge().equals(PinEdge.FALLING) )    {
                      System.out.println("F");
            @Override
                  if(event.getEdge().equals(PinEdge.RISING) )    {
                      System.out.println("R");
My loop code instead is this:
if(InputOutputManager.getInstance().getSpi_cs().getState().isHigh())    {
           System.out.println("H");
      else    {
          System.out.println("L");
If I physically connect the interrupt input with ground I read "F", when I physically connect the interrupt input with 3,3V I read "R". So the interrupt works good.
So my question is: why with interrupt I can't detect FALLING and RISING events from the 500Hz signal?
thanks to everyone
calucio24
Re: Problem with 500 Hz signal detection interrupt with PI4J
Thu Apr 18, 2019 3:50 pm
I have used the wrong class. I fix it with the following code:
if (Gpio.wiringPiSetup() == -1) {
            System.out.println(" ==>> GPIO SETUP FAILED");
            return;
        Gpio.pinMode(4, Gpio.INPUT) ;
        Gpio.pullUpDnControl(4, Gpio.PUD_UP);
        Gpio.wiringPiISR(4, Gpio.INT_EDGE_FALLING, new GpioInterruptCallback() {
            @Override
            public void callback(int pin) {
                mosiManager.setIsWritingTime(false);
Return to “Java”
