Marcel92
Cross compiling Windows to Pi3
Thu Mar 28, 2019 10:40 pm
Hi guys,
First of all, i never worked with a raspberry pi or did cross compiling, so i have a question.
is there a toolchain i can use for cross compiling in java? My host system is windows and i have a Raspberry Pi 3 B+(OS Raspbian).
The only toolchain i found is for C++.
Thanks in advance
Imperf3kt
Re: Cross compiling Windows to Pi3
Thu Mar 28, 2019 11:58 pm
Google is ubiquitous - Try it today, it's free!
https://opensource.com/life/16/10/how-ask-technical-questions
Gavinmc42
Fri Mar 29, 2019 12:58 am
NetBeans works fine too, Pi is just a networked target.
Been some time since I used it for JavaFX on Pi's.
Most of the new stuff is now OpenJDK ,OpenFX etc.
I'm dancing on Rainbows.
HawaiianPi
Fri Mar 29, 2019 4:28 am
Java is Java, it doesn't require anything special (you're building Java code, not machine specific code). Just have the same version on both machines, then build it on your Windows PC and copy it to your Pi (you only need JRE on the target machine).
Return to “Java”
