masoric
Adafruit Python Sensor Library in Java
Mon Aug 27, 2018 7:31 pm
Good Afternoon,
I was just curious if anyone was using the Adafruit Python Sensor library from within a Java application. If so what was the best mechanism to make it work? I have much more experience with .net programming than with Java or Py so my apologies if this is a basic question.
Specifically I am trying to use the DHT sensory library to pull the Temp and Humidity into the Java app.
dht.read_retry(dht.DHT22, 4)
Any pointers would be appreciated.
Regards
masoric
Re: Adafruit Python Sensor Library in Java
Wed Aug 29, 2018 1:28 pm
I ended up caving in and used python to read the value and update the DB.
static916
Tue Oct 16, 2018 10:50 pm
I had issues with Pi4J and the DHT11/22 but found code here that made it sometimes work: https://stackoverflow.com/questions/284 ... using-pi4j
Finally I ended up updating to the latest build of Raspian and Pi4J and the comments in stackoverflow and the code ended being 80% reliable. Which made it that I'd take several samples and average them out.
Best of luck!
Return to “Java”
Who is online
Users browsing this forum: No registered users and 2 guests
